1. Re: Nikon D7200 e file Nef (Raw)
ssprengel Aug 31, 2015 6:51 AM (in response to massimop74033917)1 person found this helpfulThe D7200 was first supported by Camera Raw 9.0 and Lightroom 6.0.
ACR 9.0 only works with PS-CS6 & PS-CC.
You can use the DNG Converter 9.0 or newer, to create DNGs from the NEFs and the DNGs will work in the older Camera Raw plug-in you have.
The DNG Converter is here: http://www.adobe.com/downloads/updates.html
2. Re: Nikon D7200 e file Nef (Raw)
massimop74033917 Sep 1, 2015 11:04 AM (in response to ssprengel)Ok, ho fatto come detto, ho scaricato DNG e...ho provato a convertire il file Raw prodotto dalla mia D3100 e tutto ok.
Ho fatto identica operazione con quello della D 7200 e la risposta non è cambiata: " la cartella non contiene alcun file da fotocamera in formato supportato".
che posso fare ?
Grazie
3. Re: Nikon D7200 e file Nef (Raw)
999axmelissariosJan 25, 2016 12:46 PM (in response to ssprengel)
Are you able to follow-up with the OP? Seems like they are still getting the same error.
Melissa
4. Re: Nikon D7200 e file Nef (Raw)
ssprengel Jan 25, 2016 1:09 PM (in response to 999axmelissarios)In the intervening 5 months, I'd guess it's been figured out, as there have been no other posts. The issue was likely that the OP was double-clicking down into the folder instead of single-clicking to select the folder without opening it. A deficiency in the DNG Converter since time immemorial.
