2 Replies Latest reply on Sep 2, 2015 3:23 AM by ritucf
    Coldfusion service not starting after system restart
    ritucf
      After I restarted server today , coldfusion application service could not start server.
      I tried to restart it manually through component service , but it did not.
      There were no logs in C:\ColdFusion11\cfusion\logs.
      Message in window's system log is :
      Log Name:      System
      Source:        Service Control Manager
      Date:          9/1/2015 1:59:12 AM
      Event ID:      7024
      Task Category: None
      Level:         Error
      Keywords:      Classic
      User:          N/A
      Computer:      reporting
      Description:
      The ColdFusion 11 Application Server service terminated with the following service-specific error:
      The system cannot find the file specified.
      Event Xml:
      <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
        <System>
          <Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
          <EventID Qualifiers="49152">7024</EventID>
          <Version>0</Version>
          <Level>2</Level>
          <Task>0</Task>
          <Opcode>0</Opcode>
          <Keywords>0x8080000000000000</Keywords>
          <TimeCreated SystemTime="2015-09-01T08:59:12.335662300Z" />
          <EventRecordID>37578</EventRecordID>
          <Correlation />
          <Execution ProcessID="664" ThreadID="4220" />
          <Channel>System</Channel>
          <Computer>reporting</Computer>
          <Security />
        </System>
        <EventData>
          <Data Name="param1">ColdFusion 11 Application Server</Data>
          <Data Name="param2">%%2</Data>
          <Binary>43006F006C00640046007500730069006F006E0020003100310020004100700070006C00690063006 100740069006F006E0020005300650072007600650072000000</Binary>
        </EventData>
      </Event>
      Message in Application log :
      Log Name:      Application
      Source:        ColdFusion 11 Application Server
      Date:          9/1/2015 2:13:23 AM
      Event ID:      259
      The description for Event ID 259 from source ColdFusion 11 Application Server cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
      If the event originated on another computer, the display information had to be saved with the event.
      The following information was included with the event:
      the message resource is present but the message is not found in the string/message table
          <Provider Name="ColdFusion 11 Application Server" />
          <EventID Qualifiers="49153">259</EventID>
          <Keywords>0x80000000000000</Keywords>
          <TimeCreated SystemTime="2015-09-01T09:13:23.000000000Z" />
          <EventRecordID>11826</EventRecordID>
          <Channel>Application</Channel>
          </Data>
          <Data>ColdFusion 11 Application Server</Data>
        </EventData>
      </Event>
      Please suggest the possible solution as I could not found much about it on web.
