• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
#3669: Bad input size
Community Beginner ,
Sep 01, 2015 Sep 01, 2015
I am having some trouble with some ATF textures I am uploading to memory on a few different IOS devices.
When the texture starts to upload using Texture.uploadCompressedTextureFromByteArray( data, offset, isAsync ) I get a #3669: Bad Input Size error occur.
Taking at look at the properties in the data I can see that the position is always 16. Im not sure if that has anything to do with it but i thought i would mention it.
I have tried using the png2Atf and also using Texture Packer but i get the same result.
I can replicate the issue every time on iPad Air IOS 8.4.1, we have also replicated it on a number of other IOS devices running different IOS versions.
My textures are 2048x2048 and I am using baselineConstrained for the Stage3D profile.
I am using Starling but I have used the following code for testing to make sure that it is not starling that is failing.
It would also be good to know that I load about 4 other ATF textures successfully before it tries fails to load this texture. I have opened up Adobe Scout and it looks like I have enough graphics memory available so i'm not really sure what is going on.
Below is my test code. This triggers once the core assets have been loaded and the home screen has been displayed. I have also moved this before I load anything else and it still fails.
  var file:File = GGGlobals.EPISODE_PATH( "2" ).resolvePath( "x2/episode.atf" );
  var ba:ByteArray = new ByteArray();
  var fs:FileStream = new FileStream();
  fs.open( file, FileMode.READ );
  fs.readBytes( ba );
  var texture:flash.display3D.textures.Texture = Starling.context.createTexture(2048, 2048, Context3DTextureFormat.BGRA, false);
  texture.uploadCompressedTextureFromByteArray( ba, 0 );
Any help would be really appreciated.
Chris
TOPICS
Development
Views
1.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Sep 10, 2015 Sep 10, 2015
Hi All,
I have managed to fix the issue. My startup in the app was causing the ATF bytes to become corrupt.
In my startup I move the ATF files from the Application Directory to the Documents directory and the app was continuing before the process had finished moving each file. The bytes were the correct length but the the wrong values.
Apologies for not getting back sooner. Thank you for your responses.
Chris
Votes
Translate
Translate
Sep 03, 2015 Sep 03, 2015
My issue is now happening on two Android devices running 4.4.2 and 5.1 running AIR 18.
The ATF files are not using ETC or PVRTC they are just containers for PNG as the file size is smaller than normal PNGs.
Can anyone help? Its driving me mad and the project is for a high profile client.
Votes
Translate
Translate
Report
Report
Engaged ,
maybe this post on the starling forum will help: http://forum.starling-framework.org/topic/assetmanager-bad-input-size
I'm not familiar with using ATF as a "container for PNG" - do you mean you're using RGB format inside the ATF?
If you're not using compressed textures, you might as well use PNG - PNGs are compressed pretty well, and IPAs are compressed as well (zip file).
I'm currently using ATF PVRTC on ios and ATF ETC on android for my starling games, I switched from PNG for smaller memory usage.  However, I had to pull a few tricks due to compression artifacts.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
HI Chris,
Could you please share a sample app and ATF that you are using . It would be easier for us to debug using it.
-Vivek
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Below could be the reason for method uploadCompressedTextureFromByteArray:
http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/display3D/textures/Texture....
public function uploadCompressedTextureFromByteArray(data:ByteArray, byteArrayOffset:uint, async:Boolean = false):void
"when there is integer overflow of byteArrayOffset or if byteArrayOffset + 6 is greater than the length of data, or if the number of bytes available from byteArrayOffsetto the end of the data byte array is less than the amount of data required for ATF texture"
Please try this. If the issue still exist, please let us know.
Votes
Translate
Translate
Report
Report
LATEST
Hi All,
Chris
Votes
Translate
Translate
Report
Report
