• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
ColdFusion 9 and Java 8
New Here ,
Sep 01, 2015 Sep 01, 2015
For security reasons, we I have been asked to update a ColdFusion 9 Enterprise (9,0,2,282541) application's Java 8. Is it possible to configure ColdFusion 9 to run on Java 8? I have successfully configured it to work with the last version of Java 7 (1.7.0_80).
When I attempt to use the Java 8 JRE, the site throws an Error 500, with the message ""Error","jrpp-0","08/31/15","16:48:21","cfadmin","javax.xml.parsers.DocumentBuilderFactory.setFeature(Ljava/lang/String;Z)" in the exception log.
Thanks!
Views
2.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate , Sep 01, 2015 Sep 01, 2015
Java 8 will not work with CF9. Support for this has only been introduced into CF10 and 11 this year. As CF 9 is EoL, support was not put in.
Which JDK is supported with ColdFusion 9, 10, and 11? — Adobe ColdFusion Blog
Votes
Translate
Translate
Advocate ,
Votes
Translate
Translate
Report
Report
New Here ,
Thanks for your quick response and confirming. I wanted to make sure I wasn't missing a simple setting or file copy that would make it run.
Thanks again.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Sep 02, 2015 Sep 02, 2015
@haxtbh I don't think your statement is correct -- it is possible to run Java 8 on CF9, however it is not supported. The support issue is somewhat moot now anyways because CF9 has reached End Of Life so there is no official support.
If you do want to run Java 8 on CF9 make sure you apply all the hotfixes first, especially the one where they added support for Java 7.
Here's an example showing someone getting Java8 running on CF9: http://www.trunkful.com/index.cfm/2014/12/8/Preventing-SSLv3-Fallback-in-ColdFusion
For most Java apps updating the JVM to a newer version does not cause major issues, with CF there are some parts that are not pure java, so you might see issues with those parts, or if a library was using an undocumented class in a JVM that was removed, etc.
Granted since CF9 is not supported by adobe the best route is to upgrade to CF10 or CF11.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
If you are using Solr collections on CF9, Java 7 u 31 and later (including Java 8) will break Solr collections on CF9.  Not sure about CF10.  If you download CF11 that already has Java 8, Solr collections seem to work fine.
If you are not using Solr collections and have no intention of doing so, this is not going to be an issue.  Just a heads-up, in case Solr collections are a consideration.
HTH,
^_^
Votes
Translate
Translate
Report
Report
Resources
Documentation
