3 Replies Latest reply on Sep 8, 2015 5:25 AM by sandy_mc
    Tone Curve data in 5DS R vs no Tone Curve data in 5DmkIII DNG Profiles?
    mike mccue
      Hello,
      I have been using dcpTool to look at .xml displays of the Adobe Standard .dcp DNG Profiles.
      I have been doing so in the hopes of replacing the Tone Curve data in the 5DS R files with something that yields results closer to that which I accustomed with for my older Canon 5D series cameras.
      I looked at the 5DS R Tone Curve data and it is described with 65 points.
      I expected to find Tone Curve data in the Canon 5DmkIII DNG profile which I could compare to the tone curve in the Canon 5DS R DNG profile and I quickly learned that the 5DmkIII ( and 5DmkII) does not have any specific Tone Curve data listed in its DNG profile.
      I also looked at an .xml display of a DNG Profile that I have generated for the 5DS R with Adobe DNG Profile Editor using a ColorChecker chart. In that profile I found specific Tone Curve data, and it was described with only 7 points.
      I have two questions:
      First; Is the Tone Curve data supplied so as to support some advanced feature in the 5DS R profiling or has it simply been added to adjust the curve to appear different than would occur with a default? Is there any implication to simply removing the Tone Curve data from the 5DS R profiles other than effecting an adjustment in light values?
      Second; Does the density of the tone curve data serve any purpose other than to potentially describe a complexly shaped curve in more detail? Is interpolation used to allow a smooth or simple curve, described with less points, to seem as useful as a curve that is described with many points?
      Thank you.
