25 Replies Latest reply on Dec 15, 2015 12:02 PM by viettamluu
    Olympus EM-10 MkII Support?
    MarkyM
      I have a new Olympus EM-10 MkII and Lightroom 6.1.1 says that it's RAW files are unsupported. When will support be added for the EM-10 MkII?
      Is there anything I can do in the meantime to get the MkII's .orf files recognized?
      Thanks!
        • 1. Re: Olympus EM-10 MkII Support?
          dj_paige Level 9
          You'd have to use the software provided by the manufacturer.
          Most likely, the next release of Lightroom will support this camera, but I can't make any guarantees, either.
          • 2. Re: Olympus EM-10 MkII Support?
            khatwani Adobe Employee (Admin)
            Hi There,
            As suggested by Paige you can use the Company's software also you can check  this list that continuously gets updated Cameras supported by Camera Raw
            The above link contains the complete list of cameras supported with respective version of Adobe Lightroom.
            Jitendra
            • 3. Re: Olympus EM-10 MkII Support?
              MarkyM Level 1
              Thank you.
              I would never use the Olympus supplied software. it is terrible. I may as well just use camera .jpg's for now.
              I have been a Lightroom user since version 1. I'm just wondering if perhaps there might be a beta version that supports the MkII already or perhaps there is a way to edit the .orf file to make it work in LR 6.1.1 until the next release. I don't think the sensor has changed between the original EM-10 and the MkII.
              • 4. Re: Olympus EM-10 MkII Support?
                dj_paige Level 9
                No Adobe software supports the raw from this camera, as of today. There is no beta version available.
                • 5. Re: Olympus EM-10 MkII Support?
                  ryan19853
                  It's odd because I just had the original E-M10 and just returned it for the Mark II.  Lightroom has no problem reading the .orf files from the E-M10.  The Mark II generates the same .orf files.
                  The Olympus software is terrible.  Only option is converting to a 50mb TIFF file.
                  • 6. Re: Olympus EM-10 MkII Support?
                    ssprengel Adobe Community Professional & MVP
                    Every model camera’s photos must be analyzed by Adobe and a specific profile or profiles created for it.  Even if the sensor is the same, there might be some small change in the electronics afterwards or the lens before that causes the pixels’ range of values or color or lens-distortions to be slightly different so each camera needs a new profile.
                    • 7. Re: Olympus EM-10 MkII Support?
                      ryan19853 Level 1
                      Thanks, that makes sense.  Though still discouraging.  I just signed up for the CC photography membership and now I can't use it like I wanted.
                      Does Adobe update the Camera RAW and DNG Converter faster than Lightroom?  That would be a much better stopgap before Lightroom adds support instead of using the bad Olympus converter.
                      • 8. Re: Olympus EM-10 MkII Support?
                        dj_paige Level 9
                        Usually these happen at the same speed. Sometimes the DNG converter is released a week or so before Lightroom updates.
                        • 9. Re: Olympus EM-10 MkII Support?
                          MarkyM Level 1
                          OK thanks.
                          Better to take the time to do it right than rush something out too quickly.
                          • 10. Re: Olympus EM-10 MkII Support?
                            viettamluu
                            I recently got an E-M10 Mark II and stumbled into this same issue. I'm using Lightroom 5.7 / DNG Converter 9.1.1.
                            I reasoned that since the MkII has the same sensor (heck even the same kit lens) as the original E-M10, if I could somehow trick LR/DNG into treating the ORF files as if they came from an (original) E-M10, things would probably work just fine.
                            Dumping the EXIF information from ORF files for both cameras I noted two importanted differences going from the old to new model: "Make" changed from "OLYMPUS IMAGING CORP." to "OLYMPUS CORPORATION", and "Camera Model Name" (as exiftool calls it) from "E-M10" to "E-M10MarkII".
                            First I tried to see if I could tinker with the Adobe .dct camera definition files to make LR/DNG accept the new files, but couldn't find any obvious way to do that.
                            Then I tried using exiftool to change the MkII .ORF files' EXIF data to appear as if they came from an original E-M10. That worked for changing "Make" but exiftool refused to change the "Camera" tag, saying it wasn't "writable".
                            So I said, "It's my file, I'll be the one to decide what's writable!" and used a binary/hex editor to change the camera model to "E-M10"... and presto! Both Lightroom and DNG converter now happily accept the modified MarkII ORF files!
                            I'm working on an app to do the conversion in a more user-friendly way. Should be ready in a day or two.
                            • 11. Re: Olympus EM-10 MkII Support?
                              dj_paige Level 9
                              While it may be the same sensor, the information in the E-M10 Mark II .ORF files may be stored differently than the information in the E-M10 file, and so by doing this you are taking a risk that the information will not be properly read into Lightroom. Furthermore, Adobe will optimize the LR software to render the RAW images for the E-M10 Mark II files, and this may require different rendering than the E-M10 files.
                              So, yes, these are your files, but you are still taking risks by doing this.
                              Lastly, at least one reviewer says the sensors are different: Olympus OM-D E-M10 Mark II Preview - CNET
                              • 12. Re: Olympus EM-10 MkII Support?
                                viettamluu Level 1
                                Fair enough, though I think you're giving Adobe a bit too much credit there. ("Optimize the LR software ... for the E-M10 Mark II files"... hahah!)
                                Granted, lack of evidence is hardly proof, but every other software I have (Photomatix, Picasa, etc.) have handled the MarkII ORFs perfectly, so I've seen no evidence the format has changed in any significant way.
                                I have a couple thousand test photos and will let you know how it goes. And will make backup copies, obviously.
                                • 13. Re: Olympus EM-10 MkII Support?
                                  viettamluu Level 1
                                  Took a bit longer than I expected as I decided to give myself Windows programming refresher and C# primer in the process:
                                  Seems to be working well enough; Adobe DNG converter has crunched through about half of the 1800 files that I converted (my converter only has to whack a few dozen bytes in each file so is very fast, ~30 seconds to convert 1800 files / ~45 GB; Adobe DNG... I've no idea what it's doing--hopefully a lot of magic--but it's been at it for over an hour).
                                  Anyway if you want give it a try: ORFConverter.zip - Google Drive
                                  I tried making it a fancy signed Windows app installer package but that turned into a pointless boondoggle, at least for this app which is a mere 27 KB in size.
                                  Obviously, make backup copies of your originals before trying it (the app can make backups as well; depends how much you trust it, I guess).
                                  I'll release the source code as soon as I clear it with the relevant folks at my work (Google).
                                  • 14. Re: Olympus EM-10 MkII Support?
                                    Adobe occasionally does what you're doing in LR and ACR, pretend use another camera's profile for a very new camera, but internally in the software, calling it "preliminary support".
                                    However, the colors can be slightly off, as compared with the actual new profiles have created for the new camera in the next release of software.
                                    • 15. Re: Olympus EM-10 MkII Support?
                                      SKubyshin
                                      Hi, I am thankful to you for the tip, indeed changing camera model to E-M10 does the trick.
                                      However I did not have any problem using exiftool for that - maybe there are different verions? I took the freeeware one by Phil Harvey: http://www.sno.phy.queensu.ca/~phil/exiftool/
                                      F:\conversion>dir
                                      03.10.2015 14:31 <DIR> .
                                      03.10.2015 14:31 <DIR> ..
                                      21.09.2015 00:05 15 081 340 P9210003.ORF
                                      21.09.2015 10:04 15 252 793 P9210004.ORF
                                      21.09.2015 10:04 14 713 513 P9210005.ORF
                                      21.09.2015 10:05 14 992 258 P9210006.ORF
                                      21.09.2015 10:05 14 619 364 P9210007.ORF
                                      F:\conversion>exiftool -Model=E-M10 *
                                        5 image files updated
                                      F:\conversion>dir
                                      03.10.2015 14:32 <DIR> .
                                      03.10.2015 14:32 <DIR> ..
                                      03.10.2015 14:32 14 982 250 P9210003.ORF
                                      21.09.2015 00:05 15 081 340 P9210003.ORF_original
                                      03.10.2015 14:32 15 068 142 P9210004.ORF
                                      21.09.2015 10:04 15 252 793 P9210004.ORF_original
                                      03.10.2015 14:32 14 405 790 P9210005.ORF
                                      21.09.2015 10:04 14 713 513 P9210005.ORF_original
                                      03.10.2015 14:32 14 870 072 P9210006.ORF
                                      21.09.2015 10:05 14 992 258 P9210006.ORF_original
                                      03.10.2015 14:32 14 434 554 P9210007.ORF
                                      21.09.2015 10:05 14 619 364 P9210007.ORF_original
                                      LR has no trouble at all opening the converted ORF files.
                                      Sorry you had to write the app for what's already been done, still I'm sure good programming exercise is never in vain.
                                      • 16. Re: Olympus EM-10 MkII Support?
                                        The Adobe website already lists the E-M10 II as being supported in LR 6.2, although as of Saturday noon Oct 3 in the US, LR 6.2 isn't available, yet:
                                        • 17. Re: Olympus EM-10 MkII Support?
                                          viettamluu Level 1
                                          Adobe's DNG converter 9.2 released today supports the E-M10 Mark II: Adobe - Adobe Camera Raw and DNG Converter : For Windows : Adobe DNG Converter 9.2
                                          • 18. Re: Olympus EM-10 MkII Support?
                                            ernsterdmann
                                            Got my new EM-10MkII for a few day back I was out taking some pictures today and I could not understand what was wrong and found out that I also had to buy new LR since it supports only 6.2.
                                            I'm really gratefully for you making this app. Thanks so much.
                                            • 19. Re: Olympus EM-10 MkII Support?
                                              alicejolly
                                              Well i agree to paige, you can obviously make use of software that will allow you to make the RAW files supported in your Olympus OM E-M10 Mark II. Let me also know if you find the software.
                                              • 20. Re: Olympus EM-10 MkII Support?
                                                One example of such software is LR 6.2 or newer or Photoshop CC with ACR 9.2 or newer.
                                                Another possibility is using the DNG Converter 9.2 or newer to create DNGs out of the raw files, and those DNGs (not the native raw files) will work in older Adobe products.
                                                • 21. Re: Olympus EM-10 MkII Support?
                                                  sl92487746
                                                  @viettamluu Could you furnish source code please? Many thanks.
                                                  • 22. Re: Olympus EM-10 MkII Support?
                                                    viettamluu Level 1
                                                    Would be happy to. I have to go through my employer's official procedure to do so, and it's a minor hassle which is why I hadn't bothered before (also because I figured nobody was interested ), but I'll get the ball rolling on that today.
                                                    • 23. Re: Olympus EM-10 MkII Support?
                                                      sl92487746 Level 1
                                                      Great, thanks :-)
                                                      • 24. Re: Olympus EM-10 MkII Support?
                                                        viettamluu Level 1
                                                        It's working its way through the process now. If I did everything right it should show up at https://github.com/google/ORFConverter when it gets all the approvals. I will update here if/when that happens.
                                                        • 25. Re: Olympus EM-10 MkII Support?
                                                          viettamluu Level 1
                                                          Done and done, source code is up on GitHub; apologies for the delay (final approval fell through the cracks for a couple weeks): google/ORFConverter · GitHub
