11 Replies Latest reply on Sep 7, 2015 1:06 PM by Ronald63
    object style exporting snippet naming
    hamdifem
      In my document object still text frames, I want to export as snippets
      but in the present specification in the paragraph style, but also get the name of the snippet
      I have written a code for it, but the results frustrated
      for(var p=0; p<myDoc.pages.length; p++)
          for(var i =0;i<myDoc.pages[p].textFrames.length;i++)
              var myFrame = myDoc.pages[p].textFrames[i];
                  app.findGrepPreferences = app.changeGrepPreferences = null;
                  app.findGrepPreferences.findWhat = ".+";
                  app.findGrepPreferences.appliedParagraphStyle = myParS;
      var mySearch = myFrame[i].findGrep();
      for(j=0; j<mySearch.length; j++)
              if(myFrame.appliedObjectStyle == tmc) {
                  myFrame.exportFile(ExportFormat.INDESIGN_SNIPPET, File("d:\\Yeni\\"+  mySearch[j] + ".idms"));
        • 1. Re: object style exporting snippet naming
          Ronald63 Level 4
          I don't really understand what you want to do. Could you specify ?
          Regards
          • 2. Re: object style exporting snippet naming
            hamdifem Level 1
            "tmc" has named object style
            This style has a paragraph style applied to text frame in (myPars)
            I want to make snippets s TMC
            but snippet is name myPars text value
            • 3. Re: object style exporting snippet naming
              Ronald63 Level 4
              I'm not sure that's what you want to do ...
              for(var p=0; p<myDoc.pages.length; p++){
                  for(var i =0;i<myDoc.pages[p].textFrames.length;i++){
                      app.findGrepPreferences.appliedParagraphStyle = 'foo';
                      var mySearch = myFrame.findGrep();
                      for(j=0; j<mySearch.length; j++){
                          if(myFrame.appliedObjectStyle.name == 'tmc') {
                              myFrame.exportFile(ExportFormat.INDESIGN_SNIPPET, File("~/Desktop/"+  'tmc' + ".idms"));
              • 4. Re: object style exporting snippet naming
                hamdifem Level 1
                How can I explain more
                • 5. Re: object style exporting snippet naming
                  Ronald63 Level 4
                  Try this
                          app.findGrepPreferences.appliedParagraphStyle = 'myPars';
                                  myFrame.exportFile(ExportFormat.INDESIGN_SNIPPET, File("~/Desktop/"+  mySearch[j].contents + ".idms"));
                  • 6. Re: object style exporting snippet naming
                    hamdifem Level 1
                    thanks
                    if the group I can not name in
                    How to make a snippet
                    var myGrup = myDoc.groups.everyItem();
                    var myGframe = myGrup.textFrames[0];
                    if(myGframe.appliedObjectStyle =="tmc"){
                                app.findGrepPreferences.findWhat = "\\d{4}";
                                app.findGrepPreferences.appliedParagraphStyle = "myParS";
                                var mySearch = myGframe.findGrep();
                                    myGrup.exportFile(ExportFormat.INDESIGN_SNIPPET, File("D:\\Yeni\\"+  mySearch.contents + ".idms"));
                    • 7. Re: object style exporting snippet naming
                      Ronald63 Level 4
                      Hope this help you
                      var myItems= myDoc.allPageItems;
                      var J = myItems.length;
                      while( J-- ){
                          var mItem = myItems[J];
                          if (mItem.constructor instanceof TextFrame) {
                              if(mItem.appliedObjectStyle.name =="tmc"){
                                  var mySearch = mItem.findGrep();
                                  if (mySearch.length ==1){
                                      if (mItem.parent instanceof Group){
                                          mItem.parent.exportFile(ExportFormat.INDESIGN_SNIPPET, File("~/Desktop/"+  mySearch[0].contents + ".idms"));
                                      }else{
                                          mItem.exportFile(ExportFormat.INDESIGN_SNIPPET, File("~/Desktop/"+  mySearch[0].contents + ".idms"));
                      • 8. Re: object style exporting snippet naming
                        hamdifem Level 1
                        For this code in paragraph style
                        for example
                        19     FIZ     E     3854                                 (.appliedParagraphStyle = "myParS")
                        How can we get only 4-digit numbers
                        .replace(/(\d+)(\t.+?\t)(.+?\t)(\d+)/g, '$4');
                        where I could not find how to write
                        • 9. Re: object style exporting snippet naming
                          Ronald63 Level 4
                          The above code also works in this case ...
                          • 10. Re: object style exporting snippet naming
                            hamdifem Level 1
                            yes but my list which can be
                            12     FIZ    A     651531
                            13     FIZ    B     12358743
                            14     FIZ    E     84435
                            I will take them through how
                            651531
                            12358743
                            84435
                            • 11. Re: object style exporting snippet naming
                              Ronald63 Level 4
                              Try with this ...
                              while( J-- ){
                                          //app.findGrepPreferences.findWhat = "\\d{4}";
                                          app.findGrepPreferences.findWhat = "\\d+$";
                                              }else{
