2 Replies Latest reply on Sep 2, 2015 7:25 AM by sarsaxen
    Removing Plug Ins : The "Remove" button in the Plug in Manager is greyed out
    LouMon
      Trying to remove an old version of Smugmug Plug in
      Using LR5 on an iMac. .
      The remove button is not active for any selections in the plug in manager
      Any insight would be appreciated
        • 1. Re: Removing Plug Ins : The "Remove" button in the Plug in Manager is greyed out
          99jon Adobe Community Professional & MVP
          It’s only possible to remove plugins which you have added from a user folder. The pre-installed plugins use a system folder which is why the remove button is greyed out in the Plugin Manager.
          For Smugmug you need the Publishing Manager. You can launch the dialog by clicking setup next to one on the unused services or by right-clicking on the SmugMug service and choosing edit.
          • 2. Re: Removing Plug Ins : The "Remove" button in the Plug in Manager is greyed out
            sarsaxen Adobe Employee (Admin)
            Hi LouMon,
            For Some plugins, the “Remove” button is grayed out. All this means is that this plugin has been installed in a special place that Lightroom recognizes as being for plugins. Just like any other, you can find out exactly where it is by opening the “Status” panel. Because it was installed into this special location, Lightroom loads it automatically without needing to be told to “Add” it. Because you didn’t “Add” it, you also can’t “Remove” it.
            • Go to the Plugin Manager
            • select your Plugin
            • click on show in finder and remove the plugin from the Modules folder manually.
            • Restart Lightroom and then check the plugins
            Please let us know if it helps.
            ~Sarika
