3 Replies Latest reply on Sep 7, 2015 3:15 AM by Dirk Becker
    [CS6 Applescript] tag object with existing XMLTag
    tizianofaion
      Hi everyone.
      i have an applescript that creates some text frame into the active document.
      For every of this textFrame i want that scripts use a specific tag to tag the textframe.
      For example i want that the first textFrame has tag "PaginaTipo" associated ( obviously i've created the tag PaginaTipo )
      This is the script i'm using
      set typeFile to "Samples"
      global typeTag
      set sampleCode to 12101
      tell application "Adobe InDesign CS6"
        set myPub to active document
        tell myPub
        set XMLTags to (every XML tag)
        repeat with tagz in XMLTags
        set theName to name of tagz
        if theName is equal to "PaginaTipo" then
        set typeTag to object reference of tagz
        end if
        end repeat
        log typeTag
        set myEveryItem to every page
        repeat with myItem in myEveryItem
        tell myItem
        set mySamplesTextFrame to make text frame with properties {geometric bounds:{"-23 mm", "0 mm", "-5 mm", "133.646 mm"}}
        set contents of mySamplesTextFrame to typeFile
        set applied font of characters of mySamplesTextFrame to "Impact"
        set font style of characters of mySamplesTextFrame to "Regular"
        set point size of characters of mySamplesTextFrame to 45
        set fill color of characters of mySamplesTextFrame to "Black"
        set markup tag of mySamplesTextFrame to typeTag
        set myCodeTextFrame to make text frame with properties {geometric bounds:{"-23 mm", "140 mm", "-5 mm", "273.646 mm"}}
        set contents of myCodeTextFrame to sampleCode as string
        set applied font of characters of myCodeTextFrame to "Impact"
        set font style of characters of myCodeTextFrame to "Regular"
        set point size of characters of myCodeTextFrame to 45
        set fill color of characters of myCodeTextFrame to "Black"
        exit repeat
        end tell
        end repeat
        end tell
      end tell
      but i got error at line set markup tag of mySamplesTextFrame to typeTag
      Can anyone help me ?
      thanks in advance
