7 Replies Latest reply on Sep 3, 2015 4:16 AM by Eric Lipton Ice
    indesign text fit to frame
    abspeed
      I'm looking for a script that will allow me to fit some text into a frame rather than fitting a frame to the text.
      Can anyone help please?
      All the best,
        • 1. Re: indesign text fit to frame
          Ronald63 Level 4
          Hi Allan,
          I found this snippet in my archives. I hope this will help you.
          fitContentToFrame();
          function fitContentToFrame(){
              var allTextFrames = app.activeDocument.textFrames;
              for(var i=0;i<allTextFrames.length;i++){
                  var aTextFrame= allTextFrames[i];
                  var myParagraphStyle=aTextFrame.paragraphs[0].appliedParagraphStyle;
                  var myStory =aTextFrame.parentStory;
                  var myOver=aTextFrame.overflows;
                  var myPointSize= myParagraphStyle.pointSize;
                  var myTrack= myParagraphStyle.tracking;
                  var myHScale= myParagraphStyle.horizontalScale;
                  var myLead=myParagraphStyle.leading;
                  var myMaxLead = myPointSize * 1.5;
                  var myMinLead = myPointSize * 0.8;
                  var myMaxHScale = myHScale * 1.3;
                  var myMinHScale = myHScale * 0.7;
                  var myMaxTrack = myTrack + 50;
                  var myMinTrack = myTrack - 50;
                  var myTrackIncrement =1;
                  var myLeadIncrement = 0.01;
                  var myHScaleIncrement = 0.25;
                  if (myParagraphStyle.leading==Leading.auto) {
                      var myLead=myPointSize * 1.2;
                  while (myOver==false && myLead <= myMaxLead && myHScale<= myMaxHScale && myTrack <= myMaxTrack)
                      var myLead = myLead + myLeadIncrement;
                      var myHScale = myHScale + myHScaleIncrement;
                      var myTrack = myTrack + myTrackIncrement;
                      myStory.leading = myLead;
                      myStory.horizontalScale = myHScale;
                      myStory.tracking=myTrack;
                  while (myOver==true && myLead >= myMinLead && myHScale >= myMinHScale && myTrack >= myMinTrack)
                      var myLead = myLead - myLeadIncrement;
                      var myHScale = myHScale - myHScaleIncrement;
                      var myTrack = myTrack - myTrackIncrement;
          • 2. Re: indesign text fit to frame
            abspeed Level 1
            Hi Ronald.
            Thanks for this, but unfortunately i could not get the text fitting properly. The text sizes a little, but does not fill the frame.
            I am using Indesign CC 2014 - coudl this be part of the issue?
            Cheers
            • 3. Re: indesign text fit to frame
              Ronald63 Level 4
              Hi Allan,
              Try to increases max values
              • 5. Re: indesign text fit to frame
                abspeed Level 1
                Hi, yes i found this late last night, works quite well, but i need to find a way of getting the descenders inside the text frame.
                • 6. Re: indesign text fit to frame
                  TᴀW Adobe Community Professional & MVP
                  Hmm, well, InDesign always allows descenders to extend beyond the bottom of the text frame.
                  What you could do, though, is simply set the bottom of the text frame to have, say, a 1 mm inset (this could be set as part of the object style). That should keep the descenders inside the bounds of the text frame. Does that work?
                  • 7. Re: indesign text fit to frame
                    Eric Lipton Ice Level 1
                    Is this what you want?
                    (make a textframe selection and then run the script)
                    tell application "Adobe InDesign CS6"
                        activate
                        tell document 1
                            set xFrame to item 1 of selection
                            set {w, x, y, z} to geometric bounds of xFrame
                            set orgBreedte to (z - x)
                            set transform reference point of layout window 1 to top left anchor
                            set properties of xFrame to {text frame preferences:{auto sizing type:height and width proportionally, auto sizing reference point:top left point}}
                            set a to visible bounds of xFrame
                            set x1 to second item of a
                            set x2 to fourth item of a
                            set b to x2 - x1
                            set c to orgBreedte / b * 100
                            tell xFrame to set horizontal scale to c
                            tell xFrame to set vertical scale to c
                        end tell
                    end tell
                    Grtz, EricLiptonIce
