4 Replies Latest reply on Sep 2, 2015 3:37 PM by aiScripting
    Execute and return a value (or object) from another script
    aiScripting Level 1
      I would like to be able to have some of the little functions that I use often in my scripts just as seporate scripts. so I can update then in one place and not have to copy them into every script I want to use them in.
      I am not sure if this is possible at all. But I would love to be able to just call them somehow and return values from them.
      e.g.
      Main code I need some colored swatches:
              var inCutColorCMYK = cmykColor(50, 0, 100, 0);
              var intCutSPOT = makeSwatch("CutIN", inCutColorCMYK);
      so I have these functions that I found/tweeked:
         function makeSwatch( swName, swCol) {
          var doc = app.activeDocument;
          var sel = doc.selection;
          if (!inCollection(doc.swatches, swName)) {
          var aSwatch = doc.spots.add();
          aSwatch.name = swName;
          aSwatch.color = swCol;
          aSwatch.tint = 100;
          aSwatch.colorType = ColorModel.SPOT;
          var aSwatchSpot = new SpotColor();
          aSwatchSpot.spot = aSwatch;
          return aSwatchSpot;
          }else{
              return doc.swatches.getByName(swName);
      function cmykColor(c, m, y, k) {
          var newCMYK = new CMYKColor();
          newCMYK.cyan = c;
          newCMYK.magenta = m;
          newCMYK.yellow = y;
          newCMYK.black = k;
          return newCMYK;
      function inCollection(collection, nameString) {
             var exists = false;
         try{
          for (var i = 0; i < collection.length; i++) {
              if (collection[i].name == nameString) {
                  exists = true;
          }catch(e){//alert("Illustrator needs drop kicked!!\nPlease restart Illustrator :/\n\n"+e)
              return exists;
      anyway! I keep finding my self using functions like this over and over in new scripts and hope there is a way to do this!
      Any help is appreciated!
      -Boyd
        • 1. Re: Execute and return a value (or object) from another script
          Silly-V Adobe Community Professional
          You could have a.jsx file , something like myLibrary.jsx, and in it you can have all the functions for future use. In the file it may look like this:
          ------------------------------------ Library file -----------------------------------
          #target illustrator
          function MyLibrary(){
               this.cmykColor = function(c, m, y, k) {
                   newCMYK.cyan = c;
                   newCMYK.yellow = y;
                   newCMYK.black = k;
                   return newCMYK;
              function applyFillColorTo(item, color){
                  item.fillColor = color;
              function CataloguedPathItem(pathItem){
                  var p = pathItem;
                  p.applyFillColor = function(color){
                      applyFillColorTo(this, color);
                  return p;
              this.cataloguedPathItem = function(pathItem){
                  var p = new CataloguedPathItem(pathItem);
                  return p;
          And then you can include and use that file in other scripts, like here:
          -------------------------------------- Script File ---------------------------------
          #target illustrator
          #include "C:\\Users\\Me\\Desktop\\My Adobe Scripts\\Illustrator\\MyLibrary.jsx"
          function test(){
              var mylib = new MyLibrary(); // the library script is used as an object - so items from its scope can be accessed via dot (.) like mylib.myFunction();
              if(app.documents.length > 0){
                  if(doc.selection.length > 0){
                      var myItem = mylib.cataloguedPathItem(doc.selection[0]);
                      var myColor = mylib.cmykColor(0,100,50,0);
                      myItem.applyFillColor(myColor);
              } else {
                  alert("There is no document open.");
          test();
          The test script just colors a pathItem, but it uses functions from inside the "library" object to power the process. Note that to use the library to color a path involved instantiating that path as a custom object which has a "applyFillColor" method which uses a function from the library scope (called "applyFillColorTo")  to power it. We can't then, simply use "applyFillColorTo" function in the Script File scope, because it is protected by the MyLibrary object.
          • 2. Re: Execute and return a value (or object) from another script
            Of course, you can just keep simple functions inside the MyLibrary file, and use no object instances or anything, to get access to your commonly used functions.
            • 3. Re: Execute and return a value (or object) from another script
              aiScripting Level 1
              wow! this sounds EXACTLY like what I have been looking for!
              Thanks a million!!!!!!
              -Boyd
              • 4. Re: Execute and return a value (or object) from another script
                aiScripting Level 1
                Yes! just tested this and this is so perfect for what I need!!
