1 Reply Latest reply on Sep 7, 2015 9:13 PM by KoMaruyama
    Adobe Draw how to unmerge a layer?
    financed60164355 Level 1
      I've been working on a project now for about a week and ran out of layers, So I merge  down a layer. "YIKES that didn't look right!" So now I have ta layer merged down with a not her layer and the merger didn't  work out so well...How do I get back and unmerg the mess?
      Thank you in advance
        • 1. Re: Adobe Draw how to unmerge a layer?
          KoMaruyama Adobe Community Professional
          BAD NEWS: There is no 'unmerge' option - probably because Draw doesn't know which parts of the layer you want to separate, and it doesn't know how to select multiple parts of a layer to 'split to new layer'.
          For this reason, like my desktop work, I usually prefer to create versions, duplicating states of the work as I go.
          GOOD NEWS: You can always send it to Illustrator, and create separate layers there.  Although you've merged the vector elements in Draw, they are still separate elements each time you begin a new stroke, it's a separate shape.  Illustrator will sort it out for you.
          If you erase elements on a merged layer, you're creating multiple separated shapes.  It takes some getting used to.
          Usually I merge work that no longer needs to be touched/moved/edited in Draw.  Wanna make an edit? That happens in clean up within Illustrator anyway.
