1 Reply Latest reply on Nov 21, 2015 12:50 AM by RahulTyagi_
    Create preflight xml report using javascript
    Balav483 Level 1
      Hi friends
          I would like to run a preflight and export its report in xml format. I tried the below code, but output generated by code is not similar to the output generated manually using acrobat
      var oProfile = Preflight.getProfileByName('testing');
      if( oProfile != undefined )
      var oThermometer = app.thermometer;
      var myPreflightResult = this.preflight( oProfile, false, oThermometer);
      var cXMLData = myPreflightResult.report(oThermometer);
      var oXMLData = XMLData.parse(cXMLData, false);
      console.println(cXMLData);
      Output:
      <?xml version="1.0" encoding="UTF-8" ?>
      <report xsi:schemaLocation="http://www.callassoftware.com/namespace/js js_results_schema.xsd" xmlns="http://www.callassoftware.com/namespace/js" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
        <fixups>
        </fixups>
        <results>
        <result severity="Error">
        <rule>testing</rule>
        <doc hits="1"></doc>
        </result>
        </results>
      </report>
      Thanks and Regards
      Bala
