The How-tos article outlines how to
List top posts by number of comments
but with the displayed code we just can't get to work....something seems to missing
Has anybody implemented it? and/or could post the complete code?
Thanks in advance
Hartmut
Hi Mihai,
Thanks for your reply and your directions
We had a deeper look into it and it seems that the <p> </p> marks are not the issue, but whenever an image (as it is often the case in blog posts), or generally any other html tag, is partially included in the 60 character truncated body, the sorting script breaks.
The <p>{{ i.body | truncate:60, "..." }}</p>
could be replaced by
{{ i.body | strip_html | truncate:60, "..." }} // delete all html markup, then truncate to 60 char
or
<p>{{ i.metaDescript
...Copy link to clipboard
Hey Hartmut,
What specifically doesn't work, the sorting or the rendering of the blog posts?
Please make sure you load jQuery before the script if you put it inline, if not, then add the script to an external file that's loaded after jQuery.
Is it possible you can share the link?
Mihai
Hi Mihai,
The sorting seems to be the problem
Below, please see the code on page: Blog posts by # of comments
<!DOCTYPE html>
<html>
<head>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/2.1.4/jquery.min.js"></script>
<title>Blog posts by # of comments</title>
<meta name="description" content="Blog posts by # of comments" />
</head>
<body>
{module_blog render="item" filter="item" itemId="8197" collection="myBlog" template=""}
{% for b in myBlog.items -%}
{module_blogpostlist render="collection" blogId="8197" rowCount="{{ b.totalPosts }}" collection="mostCommented" template=""}
{% if mostCommented.items -%}
<!-- BEGIN MOST TALKED ABOUT -->
<h2>Most Talked About</h2>
<div id="blogpostlist" style="display:none">
{% for i in mostCommented.items -%}
<div data-comment-number="{{ i.commentsCount }}" class="postitem">
<div class="col-md-3" style="font-size:50px;">
</div>
<div class="col-md-9">
<h3><a href="{{ i.url }}">{{ i.title }}</a></h3>
</div>
</div>
{%endfor%}
</div>
<!-- END MOST TALKED ABOUT -->
{%endif%}
{%endfor%}
// Set a variable to the wrapper div where your list items reside
var $wrapper = $('#blogpostlist');
// Set a variable to the following string for shorter code
var $attr = 'data-comment-number';
// Find the elements in the wrapper that contain the postitem class and sort them
var sortedPosts = $wrapper.find(".postitem")
.sort(function (a,b) {
return b.getAttribute($attr) - a.getAttribute($attr);
// Clear the elements in the wrapper and then show it
$wrapper.empty()
.show();
// For this example we want only 3 posts and let's put back the data in the wrapper using appendTo
sortedPosts.slice(0,3)
.appendTo($wrapper);
</script>
</body>
</html>
Hi again,
Try replacing:
with
and check the post content as there seem to be some issues with that which wrecks the html.
E.g view-source:http://www.eworkswsi.com.cy/Test%20pages/blog-post-by-comments.html
Check line 213
M.
Hi Mihai,
or
<p>{{ i.metaDescription }}</p> // use the posts metadescription
Hartmut
Hi Hartmut,
That's true, will modify the docs to use the strip_html filter.
Mihai
