5 Replies Latest reply on Sep 18, 2015 2:52 AM by BKBK
    websockets in CF11
    Rick W
      Hello, I have been trying to get websockets working in our CF 11 update 6/IIS8 server to no success.  I would love to use SSL, but as part of my testing I have even tried non-ssl with no luck. The instructions I have followed are these, Using WebSocket with ColdFusion 11 | Adobe Developer Connection.
      Using Chrome I see that I receive this for standard proxy configuration on a non-SSL connection, "Error during WebSocket handshake: Unexpected response code: 200." This does show as a ws connection.
      If I configure the builtin server and use SSL the error is WebSocket connection to 'wss://name.of.server:8543/cfusion/cfusion' failed: Error in connection establishment: net::ERR_TIMED_OUT."  The name of server is correct just removed here since I've been testing at times without firewall to eliminate that problem. I don't get where the cfusion/cfusion is derived from however. I am not sure why it isn't using cfws there that the non-ssl ones do. Port 8543 is open (even when the firewall is on).
      If I set secure = false and redo the builtin server without SSL, I get "failed: Error in connection establishment: net::ERR_CONNECTION_TIMED_OUT" and it is for ws.
      I have seen a different page discuss changes needing made to server.xml. When I try them, I cannot get CF to restart.
      IIS has websockets on, and I see the cfws directory in the IIS manager.
      Thanks for any ideas as to what I might be missing.
        • 1. Re: websockets in CF11
          nic_tunney Adobe Community Professional
          Did you name any websocket channels in your Application.cfc?  Like this:
          this.wschannels = [{name="stocks"},{name="chat"}];
          • 2. Re: websockets in CF11
            Rick W Level 1
            Thank you for the reply, the code we have has this in it:
              <cfset this.name = "Cf11Examples">
              <cfset this.wschannels = [{name="chat"}]>
            • 3. Re: websockets in CF11
              That does your cfwebsocket call look like?  Are you then using JS after defining the endpoint in cfwebsocket?  If so can you also include that code?
              • 4. Re: websockets in CF11
                Rick W Level 1
                Thanks for helping look. Our programmer said all this was plagerized, we are just wanting something working before we start customization. I have tried setting security to false and changing CF Admin to not use SSL just to see if the problem is with our cert, but that hasn't helped. I grabbed the programs, here is application.cfc:
                And here is the index.cfm:
                <cfwebsocket name="webSocketObj"
                             secure="true" />
                             <doctype html>
                <title>WebSocket Example</title>
                             messageHandler =  function(aEvent,aToken) {
                                    if (aEvent.data) {
                           var txt=document.getElementById("msgArea");
                           txt.innerHTML += aEvent.data  +"<br />";
                            openHandler = function() {
                            alert("Connection is open");
                            closeHandler= function() {
                            alert("Connection Closed");
                              errorHandler = function() {
                                 sendMessage = function() {
                            var text = window.prompt("Enter some text","");
                            if (text) {
                                webSocketObj.publish("chat", text);
                    <div id="msgArea" />
                    <input type="button" value="Send Message" onClick="sendMessage()">
                Thanks again.
                • 5. Re: websockets in CF11
                  BKBK Adobe Community Professional & MVP
                  I got your code to work as expected. I copied your exact code to my ColdFusion 11 set-up, with two exceptions.
                  1) I changed the secure attribute to false.
                  2) I added form tags. In other words, I replaced the input tag with
                  I left the websocket settings in the Coldfusion Administrator at their default values, as follows:
