0 Replies Latest reply on Sep 4, 2015 1:00 AM by Tayyab Hussain
    Retrieving Data using jqGrid
    Tayyab Hussain Level 1
      I am trying to retrieve data into jqGrid but it seems that my data is not converted to json or maybe the case is something else. In short can't populate the jqGrid. My files are as follows
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title>Untitled Document</title>
      <link rel="stylesheet" type="text/css" media="screen" href="steel/grid.css" />
      <link rel="stylesheet" type="text/css" media="screen" href="steel/jqModal.css" />
      <script src="js/jquery-1.11.0.min.js"></script>
      <script src="js/jquery.jqGrid.min.js" type="text/javascript"></script>
      <script src="src/jqModal.js" type="text/javascript"></script>
      <script src="src/jqDnR.js" type="text/javascript"></script>
      <script src="src/jquery.fmatter.js" type="text/javascript"></script>
      <table id="list" class="scroll" cellpadding="0" cellspacing="0"></table>
      <div id="pager" class="scroll" style="text-align:center;"></div>
      <div id="mysearch"></div>
                      url:"Users.cfc?method=getUsers", //CFC that will return the users
                      datatype: "json", //We specify that the datatype we will be using will be JSON
                      colNames:['ID','FirstName','LastName', 'DisplayName','UserName','UserAccountingCode','Phone'], //Column Names
                      //The Column Model to define the data. Note you can make columns non sortable, specify width, alignment, etc.
                      colModel :[
                          {name:'id',index:'id', width:50, sorttype:"int"},
                          {name:'FirstName',index:'FirstName', width:150, sorttype:"string"},
                          {name:'LastName',index:'LastName', width:150, align:"left",sorttype:"string"},
                          {name:'DisplayName',index:'DisplayName', width:150, align:"left",sorttype:"string"},
                          {name:'UserName',index:'UserName', width:150,align:"left",sorttype:"string"},
                          {name:'UserAccountingCode',index:'UserAccountingCode', width:150, sortable:false},
                          {name:'Phone',index:'Phone', width:150, sortable:false}
                      pager: $('#pager'), //The div we have specified, tells jqGrid where to put the pager
                      rowNum:4, //Number of records we want to show per page
                      rowList:[4,8,12], //Row List, to allow user to select how many rows they want to see per page
                      sortorder: "asc", //Default sort order
                      sortname: "ID", //Default sort column
                      viewrecords: true, //Shows the nice message on the pager
                      imgpath: '/steel/images', //Image path for prev/next etc images
                      caption: 'Users', //Grid Name
                      height:'auto', //I like auto, so there is no blank space between. Using a fixed height can mean either a scrollbar or a blank space before the pager
                      recordtext:'Total Records', //On the demo you will notice "7 Total Records" - The Total Reocrds text comes from here
                      pgtext:'/',//You notice the 1/3, you can change the /. You can make it say 1 of 3
                      editurl:"Users.cfc?method=getUsers",//Not used right now.
                      toolbar:[true,"top"],//Shows the toolbar at the top. I will decide if I need to put anything in there later.
                      //The JSON reader. This defines what the JSON data returned from the CFC should look like
                      jsonReader: {
                          root: "ROWS", //our data
                          page: "PAGE", //current page
                          total: "TOTAL", //total pages
                          records:"RECORDS", //total records
                          cell: "", //not used
                          id: "0" //will default first column as ID
      <cffunction name="getUsers" access="remote" returnformat="json">
           <cfargument name="page" required="no" default="1" hint="Page user is on">
          <cfargument name="rows" required="no" default="10" hint="Number of Rows to display per page">
          <cfargument name="sidx" required="no" default="" hint="Sort Column">
          <cfargument name="sord" required="no" default="ASC" hint="Sort Order">
              <cfset var arrUsers = ArrayNew(1)>
              <cfquery name="selUsers" datasource="myDataSource">
                      ID, FirstName, LastName, DisplayName, UserName, UserAccountingCode, Phone
                  <!--- Sorting Here --->
                  <cfif Arguments.sidx NEQ "">
                      ORDER BY #Arguments.sidx# #Arguments.sord#
                      ORDER BY ID #Arguments.sord#
              <!--- Calculate the Start Position for the loop query.
              So, if you are on 1st page and want to display 4 rows per page, for first page you start at: (1-1)*4+1 = 1.
              If you go to page 2, you start at (2-)1*4+1 = 5 --->
              <cfset start = ((arguments.page-1)*arguments.rows)+1>
              <!--- Calculate the end row for the query. So on the first page you go from row 1 to row 4. --->
              <cfset end = (start-1) + arguments.rows>
              <!--- When building the array --->
              <cfset i = 1>
              <cfloop query="selUsers" startrow="#start#" endrow="#end#">
                  <!--- Array that will be passed back needed by jqGrid JSON implementation --->
                  <cfset arrUsers[i] = [#ID#,#FirstName#,#LastName#,#DisplayName#,#UserName#,#UserAccountingCode#,#Phone#]>
                  <cfset i = i + 1>
              <!--- Calculate the Total Number of Pages for your records. --->
              <cfset totalPages = Ceiling(selUsers.recordcount/arguments.rows)>
              <!--- The JSON return.
                  Total - Total Number of Pages we will have calculated above
                  Page - Current page user is on
                  Records - Total number of records
                  rows = our data
      <cfset stcReturn = {total=#totalPages#,page=#Arguments.page#,records=#selUsers.recordcount#,rows=arrUsers}>
          <cfreturn stcReturn>
      Please help.
      Tayyab Hussain
