3 Replies Latest reply on May 15, 2006 11:28 AM by Xodus6.com
    XML Slideshow Buttons, Help!
    Xodus6.com
      Hello! I'm an amateur when it comes to actionscript and I'm trying to modify an existing script that I found from Flash Kit to include a backwards and forwards button. It seems so simple and yet when i try to modify it, the buttons don't work. Here is the script for the slideshow (it is an XML based dynamic slideshow).
      // (c) Copyright by Andrew DiFiore. All rights reserved. DO NOT REMOVE.
      fscommand("allowscale", "false");
      Stage.scaleMode = "noScale";
      targetPhoto._visible = false;
      slides_xml = new XML();
      slides_xml.onLoad = loadSlideShow;
      slides_xml.load("slideshow_1925_1936.xml");
      slides_xml.ignoreWhite = true;
      function loadSlideShow(success) {
      if (success == true) {
      rootNode = slides_xml.firstChild;
      totalSlides = rootNode.childNodes.length;
      currentSlideNode = rootNode.firstChild;
      photos = new Array(totalSlides);
      thumbs = new Array(totalSlides);
      captions = new Array(totalSlides);
      tx = 60;
      for (i=0; i < totalSlides; i++) { // populate arrays and create thumbnails dynamically
      photos = currentSlideNode.attributes.jpegURL;
      thumbs
      = [currentSlideNode.attributes.jpegWidth,currentSlideNode.attributes.jpegHeight];
      captions = currentSlideNode.firstChild.nodeValue;
      _root.attachMovie("thumb","thumb"+i,i);
      _root["thumb"+i]._x = tx;
      _root["thumb"+i]._y = 1595; // using fixed Y coord
      _root["thumb"+i].tindex = i;
      tx += 25;
      currentSlideNode = currentSlideNode.nextSibling;
      // initialize values
      currentIndex = 0;
      targetWidth=thumbs[currentIndex][0]; // get width
      targetHeight=thumbs[currentIndex][1]; // get height;
      updateSlide();
      function updateSlide() { // load photo, update caption and status fields
      targetPhoto.loadPhoto(photos[currentIndex]);
      caption = captions[currentIndex];
      statusField = (currentIndex+1) + "/" + totalSlides;
      function slideShow() {
      if (currentIndex == totalSlides-1) { currentIndex = 0; } else { currentIndex++; }
      updateSlide();
      MovieClip.prototype.loadPhoto = function(fn) { // load external jpeg method + preloader
      this.createEmptyMovieClip("holder", 1);
      this.holder.loadMovie(fn);
      this.onEnterFrame = function() { // NOTE: could use this to display percentage to user
      if (Math.floor((this.holder.getBytesLoaded()/this.holder.getBytesTotal())*100) >= 100) {
      delete this.onEnterFrame;
      An older version of the script has a forward and backwards button, but the current version does not (the animation for the second version is much better and thus why I want to implement this instead of reverting back). This is what was used for the first version:
      nextBtn.onRelease = function() { // event handler for next button
      nextSlideNode = currentSlideNode.nextSibling;
      if (nextSlideNode == null) {
      break;
      } else {
      currentIndex++;
      updateSlide(nextSlideNode);
      currentSlideNode = nextSlideNode;
      prevBtn.onRelease = function() { // event handler for prev button
      previousSlideNode = currentSlideNode.previousSibling;
      if (previousSlideNode == null) {
      break;
      } else {
      currentIndex--;
      currentSlideNode = previousSlideNode;
      updateSlide(previousSlideNode);
      Could someone please help?? Seems like a easy solution. Thank you. df
