• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Flash Pro - Simulator stops responding .. requires full reboot. Is there an easier way?
Engaged ,
Sep 04, 2015 Sep 04, 2015
This happens way too often..  go to hit COMMAND + ENTER ..  get  "test failed" ...  Simulator is in my tray no responding. Quitting Flash Pro and re-opening does nothing. Only fix is to fully reboot my computer.
Is there a process I can kill or something to fully reset Flash Pro rather than a full computer reboot?
TOPICS
Development
Views
383
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged , Sep 11, 2015 Sep 11, 2015
I found the fix... really annoying. You have to delete your app xml file and compile again. Really annoying!
Votes
Translate
Translate
Engaged ,
I assume you've tried this, but what about force-quitting the simulator?
I use flash builder, so other than that I'm not going to be much help.
Votes
Translate
Translate
Report
Report
Engaged ,
Force quitting doesn't help.. as soon as I try to compile again it opens the simulator in a non-responsive state.
Votes
Translate
Translate
Report
Report
Engaged ,
I figured as much. I much prefer using flash builder to make apps.
Votes
Translate
Translate
Report
Report
Advocate ,
Sep 06, 2015 Sep 06, 2015
try to kill SimController process. If you don't use it - try to rename it so Flash IDE will not use it. On Windows its placed at flashproinstallfolder\Common\Configuration\Simulator\SimController.exe
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
Votes
Translate
Translate
Report
Report
