1 Reply Latest reply on Dec 6, 2006 8:38 PM by luciewong
    Xml_connector capacity
    luciewong Level 1
      How much data can an xml_connector load in from a Database through ASP?
      If the records number is about 200 the Flash Player will cause an "bad script error" .
      If I reduce the records to 100, then I have no script error!
      But 200??? is it too much?
      Any advice greatly appreciated.
        • 1. Re: Xml_connector capacity
          luciewong Level 1
          Still could not solve the problem.
          Its very bad. The Xml_connector causes a low script error every time when it loads.
          What can I do?
          Could the connector be broken?
          Because other files have the same action and there is not this loading problem.
          Any help?
