11 Replies Latest reply on May 17, 2006 1:37 PM by chrome88
    Need help with query and output
    chrome88
      I have a table that contains a list of Assets and each Asset contains a Category field, Each asset can have multiple categories assigned to it, so the Category column is populated as a list (e.g. 14, 16, 17, 19).
      The values are drawn from a Category table using the primary key as a reference no. (e.g. 14 = Keyboards, 16 = Trackballs, etc.)
      I've been trying to figure out how to output the Categories so that when the Category is displayed, the list will appear as the Category name, and not as the referenced no.
      example:
      <cfquery name="qIndex" datasource="#appDSN#">
      SELECT Asset.Reference, Asset.AssetName, Asset.Category
      FROM Asset
      WHERE Category LIKE '%#URL.Category#%'
      </cfquery>
      <cfoutput query="qIndex">
      #Asset.Reference#<br />
      #Asset.AssetName#<br />
      #Asset.Category#
      </cfoutput>
      Displays:
      AD_987738
      XYZ Keyboard
      11, 14, 17, 18
      Table for Categories are:
      CatID = Primary Key
      Category = Category Name
      CatImage = Image for header
      Thanks for any help.
        • 1. Re: Need help with query and output
          The ScareCrow Level 1
          You should redesign your db to have another table
          This table should have the asset id and the category id (I call this a bridging table)
          The category column would then be removed from the asset table.
          You then do a join on the tables to gain the category description.
          But to fix your problem with the existing structure
          Your query
          FROM Asset
          </cfquery>
          <cfset catids = ValueList(qIndex.category])>
          <cfquery name="qCat" datasource="#appDSN#">
          Select Category_Name
          From categories
          Where Category_ID IN (#catids#)
          </cfquery>
          #qIndex.Reference#<br />
          #qIndex.AssetName#<br />
          <cfloop query="qCat">
          #qCat.Category#<br>
          </cfloop>
          </cfoutput>
          Ken
          • 2. Re: Need help with query and output
            hrpatel34
            You can do it in this way aslo
            FROM Asset
            </cfquery>
            <cfquery name="qIcat" datasource="#appDSN#">
            SELECT *
            FROM Category
            </cfquery>
            <cfquery name="qIcatName" dbtype="query">
            select * from qIcat where catid in (0#Asset.Category#)
            </cfquery>
            <cfoutput query="qIcatName">
            #qIcatName.CategoryName#,
            </cfoutput>
            </cfoutput>
            • 3. Re: Need help with query and output
              chrome88 Level 1
              Your query
              FROM Asset
              </cfquery>
              From categories
              </cfquery>
              #qCat.Category#<br>
              </cfloop>
              </cfoutput>
              Ken
              Ken, Thanks. It's really close, but all of the repeating records are taking the Category output from the first record in the set and repeating it...e.g. if the first record is "Mouse, Keyboards, Trackballs", all of the subsequent records show the same.
              Also should "ValueList(qIndex.category])", have been "ValueList(qIndex.category)"?
              If there's not a way to do this using the current db, i'll try using a bridging table.
              thanks.
              paul
              • 4. Re: Need help with query and output
                philh Level 1
                You really should redesign the database. Comma-delimited lists of information in one field are a big no-no.
                Also, instead of
                <cfset catids = ValueList(qIndex.category)>
                try
                <cfset catids = ValueList(category)>
                Using the query prefix may be forcing the code to look at the first record every time.
                HTH,
                • 5. Re: Need help with query and output
                  chrome88 Level 1
                  quote:
                  Also, instead of
                  try
                  HTH,
                  Changing that varialble as noted returned the following error:
                  Parameter 1 of function ValueList which is now (Category) must be pointing to a valid query name.
                  If i redesign the database, what is a better way to store information of multiple results related to one record?
                  Thanks, Paul
                  • 6. Need help with query and output
                    paross1 Level 2
                    Entered in error.
                    • 7. Need help with query and output
                      chrome88 Level 1
                      FROM Asset
                      </cfquery>
                      SELECT *
                      FROM Category
                      </cfquery>
                      </cfquery>
                      </cfoutput>
                      </cfoutput>
                      tried this solution as well, but am getting an error message
                      Element CATEGORY is undefined in ASSET.
                      (from: select * from qIcat where catid in (0#Asset.Category#)
                      I assume that:
                      was meant to be:
                      Thanks.
                      • 8. Re: Need help with query and output
                        can you post your code as you have it for my solution ?
                        The reason you get the error from hrpatel34 solution is because the table name is being used in the cfoutput and not the query name.
                        With a "bridging" table. You will then have one record for each asset/category combination.
                        Ken
                        • 9. Re: Need help with query and output
                          chrome88 Level 1
                          Ken
                          I caught that error in hrpatel34's solution. The error message was with the revised code.
                          Code from your solution follows:
                          SELECT *
                          FROM Asset
                          </cfquery>
                          <cfset catids=ValueList(qIndex.Category)>
                          SELECT Category From Category WHERE CatID IN (#catids#)
                          </cfquery>
                          <td>
                          Category: <cfloop query="qCat">#qCat.Category#, </cfloop><br>
                          #qIndex.Asset#<br />
                          </cfoutput>
                          So if I use a bridging table, is an individual record created for each Category related to an asset, as opposed to entering as a comma delimited list?
                          Thanks again for your help Ken.
                          paul
                          • 10. Re: Need help with query and output
                            That code should work.
                            Yes, that's correct
                            Ken
                            • 11. Re: Need help with query and output
                              chrome88 Level 1
                              Finally figured this out. Had to insert an intermediate query within the output to filter each record, otherwise it was outputting the results from the first record only and repeating it.
                              SELECT *
                              FROM Asset
                              </cfquery>
                              <cfquery name="qFilter" datasource="#appDSN#">
                              SELECT CATEGORY, AssetID
                              FROM Asset
                              WHERE assetID = #qIndex.AssetID#
                              </cfquery>
                              <cfset catids=ValueList(qFilter.Category)>
                              </cfquery>
                              <td>
                              </cfoutput>
                              thanks again for the help.
                              paul
