0 Replies Latest reply on Sep 6, 2015 4:10 PM by maheshkumarp19229977
    setting up mongomk with aem author instance6
      Hi, I am receiving below warning message while starting the aem author instance v6.0 after setting up mongo db configuration in crx-quickstart/install/org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreServic e.config and crx-quickstart/bin/start file.
      06.09.2015 13:56:36.779 *WARN* [FelixStartLevel] org.apache.sling.installer.core.impl.OsgiInstallerImpl Cannot create InternalResource (resource will be ignored):InstallableResource, priority=100, id:/aem6//crx-quickstart/install/org.apache.jackrabbit.oak.plugins.document.DocumentNodeS toreService.config
      java.io.IOException: Unable to read dictionary from input stream: /aem6/crx-quickstart/install/org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreService .config
              at org.apache.sling.installer.core.impl.InternalResource.create(InternalResource.java:100)
              at org.apache.sling.installer.core.impl.OsgiInstallerImpl.createResources(OsgiInstallerImpl. java:328)
              at org.apache.sling.installer.core.impl.OsgiInstallerImpl.registerResources(OsgiInstallerImp l.java:419)
              at org.apache.sling.installer.provider.file.impl.Installer.initialSet(Installer.java:78)
              at org.apache.sling.installer.provider.file.impl.FileMonitor.<init>(FileMonitor.java:57)
              at org.apache.sling.installer.provider.file.impl.FileInstaller.start(FileInstaller.java:76)
              at org.apache.sling.installer.provider.file.impl.ServicesListener.startScanner(ServicesListe ner.java:105)
              at org.apache.sling.installer.provider.file.impl.ServicesListener.notifyChange(ServicesListe ner.java:84)
              at org.apache.sling.installer.provider.file.impl.ServicesListener$Listener.retainService(Ser vicesListener.java:165)
              at org.apache.sling.installer.provider.file.impl.ServicesListener$Listener.start(ServicesLis tener.java:140)
              at org.apache.sling.installer.provider.file.impl.ServicesListener.<init>(ServicesListener.ja va:74)
              at org.apache.sling.installer.provider.file.impl.Activator.start(Activator.java:66)
              at org.apache.felix.framework.util.SecureAction.startActivator(SecureAction.java:645)
              at org.apache.felix.framework.Felix.activateBundle(Felix.java:2152)
              at org.apache.felix.framework.Felix.startBundle(Felix.java:2070)
              at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1297)
              at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:304)
              at java.lang.Thread.run(Thread.java:744)
      Caused by: java.io.IOException: Unexpected token 78; expected: 61 (line=8, pos=4)
              at org.apache.felix.cm.file.ConfigurationHandler.readFailure(ConfigurationHandler.java:650)
              at org.apache.felix.cm.file.ConfigurationHandler.readInternal(ConfigurationHandler.java:274)
              at org.apache.felix.cm.file.ConfigurationHandler.read(ConfigurationHandler.java:237)
              at org.apache.sling.installer.core.impl.InternalResource.readDictionary(InternalResource.jav a:243)
              at org.apache.sling.installer.core.impl.InternalResource.create(InternalResource.java:98)
              ... 17 common frames omitted
      both mongodb and author aem instance are running on same server.
      please let me know where could be the probloem and anything else i missed with configuration. Kindly help
