2 Replies Latest reply on Sep 6, 2015 6:43 PM by Akash Sharma
    help with moving and saving photos
    jennabee11
      I am really struggling saving photos in different places using lightroom. I need to have them in my library and also be able to put them on a zip drive. I watched a video on how to create a folder using the drive,  I did what she showed me , the problem is they are now not in my library for personal use? only on the drive. Help please I'm so frustratedhel
        • 1. Re: help with moving and saving photos
          dj_paige Level 10
          Lightroom does not have a "save" command ... but you should be able to Export your photos to any location you want, just change the location in the Export dialog box. There is no moving of photos necessary.
          I don't know whaat you mean by "personal use". it sounds like you are saying that the photos in your library are now on the zip drive ... is that what you are saying? If so, then reverse the process, move the photos back to their original location, and then export the photos to wherever you want them to be.
          • 2. Re: help with moving and saving photos
            Akash Sharma Adobe Employee
            Hi jennabee
            What option did you selected while importing Pictures?  Copy Move or Add
            The Pictures Will be available to you in Library if you select Copy and Copy as DNG
            If you select Move and Disconnect your External Drive .Pictures will show up missing with ! sign in Lightroom
            Also the correct way of importing Pictures is to add them to catalog and keep a copy in your External drive.Not essentially Copying Pictures to External Drive.
            1. If you import while keeping TO destination(on top Right as shown in Picture below) as your Hardrive.You will have to keep your External Harddrive always connected to Computer
                2. If you import keeping TO location as Default(Pictures/Lightroom/Catalog) or on you Internal harddrive.And Make a backup copy to External drive.This way you will have a Copy of your Pictures to access from Catalog.
            Let us know if that helps
            Regards
            ~Akash
