Hello,
I'm migrating a RoboHelp Project from Version 9 to Version 11, and so far everything went smooth.
But now I faced a problem that is a show stopper:
I assume that something goes wrong in the Background that is not forwarded to the user. If I select a wrong JDK folder on purpose then I get a "normal" error message stating that no java.exe and so on could be found...
I was able to reproduce the behavior on two different PCs.
So my Question is: How can I find out what's going wrong?
- Are there logs I could look at?
- Can I turn on some kind of debug mode to get logs?
BTW: I am using Version 11.0.4
Any help would be highly appreciated as the JavaHelp Generation is critical to us.
Best regards
Andy
I did not find a answer to the "where are the logs" part of my question, but with a lot of trial and error I found a solution to the initial problem that stood in the way of generating the JavaHelp:
I downloaded and installed a very old version of the Java SDK (1.2.2_017) and installed it on the system I am working on. After installing that Java version the JavaHelp 2.0 did generate again.
Best regards
Andy
Best regards
Andy
