2 Replies Latest reply on Dec 8, 2006 11:59 AM by FasterPastor
    Director and ADOXtras
    Level 7
      Hello:
      I'm using ADOXtras and I can't get results from SQL querys.
      I use this syntax an obtain an error "comma expected"
      Do you know the correct sentence thank you.
      str="Acknowledgments"
      rst=cnn.Execute("SELECT * FROM Q WHERE [Title] = "%str%"")
        • 1. Re: Director and ADOXtras
          Level 7
          I do not use ADOxtra, but the following will work with other xtras/db's.
          - inserted directly in sql-string:
          rst=cnn.Execute("SELECT * FROM Q WHERE [Title] ='Acknowledgments'")
          - as string variable:
          rst=cnn.Execute("SELECT * FROM Q WHERE [Title] ='"&str&"'")
          (where the table in the db is named Q)
          > Hello:
          • 2. Re: Director and ADOXtras
            FasterPastor Level 1
            Anne
            In the answer above, note difference of single quotes surrounding criterion instead of double quotes. :-)
            In your post, it should say '%str%' instead of "%str%"
            In the 2nd example, in the answer above, there is (and/or should be) a single quote, then a double quote to close the text string, then the variable name, then a double quote to open the text string again, then a single quote, before finally reclosing the text string with a double quote.
