7 Replies Latest reply on Sep 9, 2015 2:30 AM by Ronald63
    find and between change
    hamdifem Level 1
      I want to change in my text frames written in paragraph style "EBT" text
      Between 1 to 3 of "ABC" text
      Between 4 and 7 "BIM" text
      Between 7 and 10 "KLM" text
      should write
      where and how an error
      var myFrame = myDoc.allPageItems;
      for(var i=0;i<myFrame.length;i++){
      //if(myFrame[i].appliedObjectStyle == tmc) {
      //if(i==5){break;}
      app.findGrepPreferences = app.changeGrepPreferences = null;
      app.findGrepPreferences.appliedParagraphStyle = "myParS";
      app.findGrepPreferences.findWhat = "EBT";
      if ((i > 0) && (i <= 3)) {var changeX = app.changeGrepPreferences.changeTo  = "ABC";}
      if ((i > 3) && (i <= 7)) {var changeX = app.changeGrepPreferences.changeTo  = "BIM";}
      if ((i > 7) && (i <= 10)) {var changeX = app.changeGrepPreferences.changeTo  = "KLM";}
      myFrame[i].texts[0].changeGrep();
        • 1. Re: find and between change
          Ronald63 Level 4
          1- it lacks a hook closure at the end "}"
          2- you do not process myFrame[0] in your code, if this frame content "EBT", it will be erased
          • 2. Re: find and between change
            hamdifem Level 1
            there I noticed the error
            all the "ABC" doing text
            if the end of the "break continue" Did I need to add
            • 3. Re: find and between change
              Ronald63 Level 4
              Sorry but i don't understand your problem ...
              • 4. Re: find and between change
                hamdifem Level 1
                the problem is to place the order
                but I was able to solve a number of rotating post (parseInt)
                var j = parseInt(myFrame[i].texts[0].contents, 10);  //****************** + ****************
                if ((j > 0) && (j <= 3)) {app.changeGrepPreferences.changeTo  = "ABC";}
                if ((j > 3) && (j <= 7)) {app.changeGrepPreferences.changeTo  = "BIM";}
                if ((j > 7) && (j <= 10)) {app.changeGrepPreferences.changeTo  = "KLM";}
                myFrame[i].changeGrep();
                but to stop after 10 "break" command in the summer when the results fiasco
                • 5. Re: find and between change
                  Ronald63 Level 4
                  Have you a screen of your doc ?
                  • 6. Re: find and between change
                    hamdifem Level 1
                    11, and 12 don't change
                                          before        after
                    • 7. Re: find and between change
                      Ronald63 Level 4
                      Dirty solution ... ;-)
                          if ((j > 0) && (j <= 3)) {app.changeGrepPreferences.changeTo  = "ABC"; myFrame[i].changeGrep(); }
                          if ((j > 3) && (j <= 7)) {app.changeGrepPreferences.changeTo  = "BIM"; myFrame[i].changeGrep(); }
                          if ((j > 7) && (j <= 10)) {app.changeGrepPreferences.changeTo  = "KLM"; myFrame[i].changeGrep(); }
