ken,
here is what i am doing to test it. i created a file called
test2.bat which contains the command "del test.txt" (test.txt
contains 3 letters abc). i then run a file called test3.cfm with
the following code:
<cfexecute name="d:\test2.bat">
</cfexecute>
then when i look on the d: drive test.txt does not get
deleted. i get no coldfusion errors so it appears the bat file
runs. when i click and run the bat file manually it does what its
supposed to and deletes test.txt file (which is within the same
directory as the bat file). so the problem is that the bat file is
not doing the commands its supposed to when coldfusion executes
it... what do you suppose is wrong? i also followed the link in
your previous help and setup a coldfusion user the way it told me
to.
thx,
-matt
