1 Reply Latest reply on Sep 9, 2015 10:40 AM by Dave LaRonde
    how to decode 10-bit video?
    LittleTin
      It looks like the decoder problem, my original video's bit depth is 10bit, this is the media info.
      Format                      : AVC
      Format/Info                : Advanced Video Codec
      Format profile              : High 10@L4.1
      Format settings, CABAC      : Yes
      Format settings, ReFrames  : 4 frames
      Codec ID                    : avc1
      Codec ID/Info              : Advanced Video Coding
      Duration                    : 1mn 32s
      Bit rate                    : 19.6 Mbps
      Maximum bit rate            : 40.6 Mbps
      Width                      : 1 920 pixels
      Height                      : 1 080 pixels
      Display aspect ratio        : 16:9
      Frame rate mode            : Constant
      Frame rate                  : 23.976 fps
      Color space                : YUV
      Chroma subsampling          : 4:2:0
      Bit depth                  : 10 bits
      Scan type                  : Progressive
      Bits/(Pixel*Frame)          : 0.395
      Stream size                : 215 MiB (100%)
      Title                      : h264@GPAC0.5.1-DEV-rev4929
      Writing library            : x264 core 128 r2216 198a7ea
      Encoding settings          : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=15.0 / qcomp=0.70 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.85
