5 Replies Latest reply on Dec 14, 2006 2:52 AM by Newsgroup_User
    extending UIComponent
    Level 7
      hi there,
      i´m trying to write a class extending the UIComponent class and firing
      "change" events using the dispatchEvent method.
      all works fine, but only if i have any other Component in the library,
      e.g. the Alert or Window component. if i delete this other component, my
      own class doesn´t fire events anymore.
      i´m sure it´s just a small thing i´m missing.
      thanx
      perry
        • 1. Re: extending UIComponent
          MotionMaker Level 1
          You need to be sure you have the EventDispatcher initialized probably in the constructor
          Initialize event dispatcher.
          EventDispatcher.initialize(this);
          You add the requist functions to the class:
          Event listener interface
          public var addEventListener:Function;
          public var removeEventListener:Function;
          public var dispatchEvent:Function;
          3. Import required classes:
          import mx.utils.Delegate;
          import mx.events.EventDispatcher;
          In addition to that you need to be sure the code using your class properly registers and also imports Delegate if you use Delegate in the addEventListener
          eg: theInstance.addEventListener( "onTheEventName", Delegate.create( this, this.theEventHandlerFunction ) );
          • 2. Re: extending UIComponent
            Level 7
            thanks for your answer.
            unfortunately things still don´t work.
            so here´s my updated code:
            [IconFile("SliderUI.png")]
            import mx.core.UIComponent;
            import mx.core.ext.UIObjectExtensions;
            [Event ("change")]
            class com.wildner.SliderUI extends UIComponent{
            static var symbolName = "SliderUI";
            static var symbolOwner = com.wildner.SliderUI;
            static var className = "SliderUI";
            [Inspectable(name="Default Value",variable="startwert",
            defaultValue="0", type="Number")]
            private var startwert:Number;
            private var wert:Number;
            private var scale:MovieClip;
            private var dragger:MovieClip;
            private var anzeige:TextField;
            private var isChanging:Boolean;
            public function Slider(){
            super.init();
            init();
            private function init(){
            isChanging = false;
            scale = this.createEmptyMovieClip("scale",1);
            scale.lineStyle(1,0x000000);
            scale.moveTo(0,5);
            scale.lineTo(100,5);
            scale.moveTo(50,0);
            scale.lineTo(50,5);
            dragger = this.createEmptyMovieClip("dragger",2);
            dragger.lineStyle(1,0xFF0000);
            dragger.moveTo(-5,0);
            dragger.beginFill(0xFF0000);
            dragger.lineTo(0,5);
            dragger.lineTo(5,0);
            dragger.lineTo(-5,0);
            dragger.endFill();
            dragger.onPress = Delegate.create(this, d_press);
            dragger.onRelease = Delegate.create(this, d_release);
            dragger.onReleaseOutside = Delegate.create(this, d_release);
            dragger.onEnterFrame = Delegate.create(this, d_enterFrame);
            anzeige = this.createTextField("anzeige",3,74,-16,30,20);
            anzeige.align="right";
            anzeige.selectable=false;
            var tfm:TextFormat = new TextFormat();
            tfm.align = "right";
            anzeige.setNewTextFormat(tfm);
            this.setValue(startwert);
            private function d_press(){
            dragger.startDrag(false,0,0,100,0);
            isChanging =true;
            private function d_release(){
            dragger.stopDrag();
            isChanging = false;
            function d_enterFrame(){
            if(isChanging){
            wert = Math.round(dragger._x);
            anzeige.text = String(wert);
            this.dispatchEvent({type:"change"});
            public function onLoad(){
            public function getValue(){
            return wert;
            public function setValue(v){
            wert = v;
            dragger._x = wert;
            this.dispatchEvent({type:"change",target:this});
            a mc in my library is connected to my AS2 class and dropped onto stage
            manually
            using:
            on(change){trace(this);}
            only gets triggered if i have a "real" UIComponent in the library (e.g.
            Alert).
            still confused.
            perry
            > constructor
            • 3. Re: extending UIComponent
              Level 7
              unfortunately things still don?t work.
              so here?s my updated code:
              [Event ("change")]
              super.init();
              init();
              isChanging = false;
              scale.moveTo(0,5);
              scale.moveTo(50,0);
              scale.lineTo(50,5);
              dragger.endFill();
              isChanging =true;
              dragger.stopDrag();
              isChanging = false;
              if(isChanging){
              return wert;
              wert = v;
              dragger._x = wert;
              manually
              using:
              Alert).
              still confused.
              perry
              • 4. Re: extending UIComponent
                Level 7
                [Event ("change")]
                super.init();
                init();
                isChanging = false;
                scale.moveTo(0,5);
                scale.moveTo(50,0);
                scale.lineTo(50,5);
                dragger.endFill();
                isChanging =true;
                dragger.stopDrag();
                isChanging = false;
                if(isChanging){
                return wert;
                wert = v;
                dragger._x = wert;
                manually
                using:
                Alert).
                still confused.
                perry
                in the
                > constructor
                properly
                addEventListener
                this,
                • 5. Re: extending UIComponent
                  Level 7
                  well, i figured it out:
                  has to be in the init() method, not in the constructor.
                  that does the trick.
                  wasn´t aware that init() is a predefined method.
                  > [Event ("change")]
                  > super.init();
                  > init();
                  > isChanging = false;
                  > scale.moveTo(0,5);
                  > scale.moveTo(50,0);
                  > scale.lineTo(50,5);
                  > dragger.endFill();
                  > isChanging =true;
                  > dragger.stopDrag();
                  > isChanging = false;
                  > if(isChanging){
                  > return wert;
                  > wert = v;
                  > dragger._x = wert;
                  > manually
                  > using:
                  > Alert).
                  > still confused.
                  > perry
                  > in the
                  > > constructor
                  > properly
                  > addEventListener
                  > this,
