5 Replies Latest reply on Dec 8, 2006 12:22 PM by Newsgroup_User
    Math Evaluate
    Level 7
      I have a shopping cart and I have the Installation of each item set up as a
      price. I have the install total for each item set to the Install price times
      the qty ordered. Then at the bottom of the cart I need to get the install
      total for all the items. That's where I am stuck. The set up looks like
      this:
      Item Qty. Install
      As5D 2 $280.00
      75GVC 1 $69.00
      Total Installation: #349.00 >>>>> this is the number I need and can't figure
      out.
      The Install for each item is using the following formula:
      <CFSET TheInstall = Evaluate((MyCart[TheIndex][6]) * (MyCart[TheIndex][3]))>
      How would I get the total installation?? I thought about using a list
      function, but I don't know exactly which function to use, or how to get them
      all added together at the end.
      Kim
        • 1. Re: Math Evaluate
          Charlie Griefer Level 1
          you don't need evaluate() in your calculation.
          <cfset theInstall = myCart[TheIndex][6] * myCart[TheIndex][3] /> will do.
          to get the grand total, just loop over myCart performing the calculations.
          <cfset grandTotal = 0 />
          <cfloop from="1" to="#arrayLen(myCart)#" index="idx">
          <cfset grandTotal = grandTotal + (myCart[idx][6] * myCart[idx][3]) />
          </cfloop>
          <cfoutput>#grandTotal#</cfoutput>
          • 2. Re: Math Evaluate
            Level 7
            I appreciate your response. But in my quest to learn would you mind telling
            me why I don't need the evaluate?
            I will give this a try.
            Kim
            "[CJ]" <webforumsuser@macromedia.com> wrote in message
            news:elac13$ft7$1@forums.macromedia.com...
            > </cfloop>
            • 3. Re: Math Evaluate
              Level 7
              Ok, CJ, the problem I am having is that some installation prices are set to
              '0' so, of course when zero is times by anything the answer is zero. Which
              wipes out my install total.
              Kim
              > </cfloop>
              • 4. Re: Math Evaluate
                you don't need the evaluate because it's extraneous.
                <cfset myValue = 5 * 4 /> <-- sets myValue to 20
                as far as your 0 issue... unless I misunderstood how your structure is set up (my understanding is element 6 is price and element 3 is quantity), it shouldn't matter if price is 0 for a given item. 0 * (whatever the quantity) is 0 for price...but that gets ADDED to the grandTotal value. so if during a given loop iteration, grandTotal is 10.50 and you add 0, you still get 10.50.
                • 5. Re: Math Evaluate
                  Level 7
                  That was my thought as well. But it didn't work and I don't know what I was
                  doing that was wrong so I added a <CFIF TheInstall EQ '0'>that is blank if
                  its equal to zero, but does the math if it's not.
                  Kim
                  news:elcdpv$f4$1@forums.macromedia.com...
                  > up
                  > quantity)
                  > during a
                  > 10.50.
