0 Replies Latest reply on Dec 10, 2006 8:48 PM by QuickStick
    Formatting HTML Text in Text component
    QuickStick
      Hi all,
      I'm trying to render some Html text in a text component, I'm getting the HTML from within an xml document as such:
      <xml><htext><p><b>Testing HTML Text</b></p><p>Here's another line.</p></htext></xml>
      If I put that into a Text component with the htmlText=htext property, the line spacing is as expected, but it seems to add in a blank space character for every character of the html code. (E.g. "<b>Testing" adds 3 extra spaces before the word "Testing").
      Renders like (using - as space character):
      --- Testing HTML Text
      -Here's another line.
      If I use the condeseWhite=true property on the Text component, it fixes the extra space characters issue, but then stuffs the line spacing up, so <p> becomes rendered like a <br>.
      Renders like:
      Testing HTML Text
      Any thoughts, or help is much appreciated, thanks in advance.
      Oz
      P.S I was trying to avoid the obvious "br" tag which will make it work and render correctly....
      <p><b>Testing HTML Text</b></p> <br/><p>Here's another line.</p>
