6 Replies Latest reply on Dec 8, 2006 8:33 PM by Newsgroup_User
    text placement
    Level 7
      Not sure if my subject line is accurate but here's what I want to do.
      I have a text sprite that displays some external text. I want the text
      to be centred in a defined area. At the moment, if the text is one line,
      it displays OK. But if it flows onto 2 lines, it isn't centred right.
      So, is the following possible (and if so how):
      * Use Lingo to align my text sprite. So whenthe text is inderted, that
      sprite will align to an invisible shape area.?
      * Determine if the text flows onto 2 lines - so can move the text
      sprite's vertical location by the required amount.
      * Determine if the text is is 1 line and insert a RETURN in the text if
      it is, to ensure I always have 2 lines. (Not sure if this will give the
      result I'm after).
      Thanks.
        • 1. Re: text placement
          Level 7
          tTextMember.alignment = #center
          put tTextMember.line.count
          If tTextMember.line.count = 1 then
          tText = tTextMember.text
          tTextMember.text = tText & RETURN
          end if
          • 2. Re: text placement
            duckets Level 1
            quote:
            The above code only counts lines by looking for return characters. If you have a long line with no return characters, it could wrap onto multiple lines, while director still considers the 'line count' to be one. As posted in a similar thread recently, the following lines will give you the vertical position of the first and last characters, from which you can determine if they are on the same visible line, or if it has wrapped onto another line:
            firstCharV = textMem.charPosToLoc(1).locV
            lastCharV = textMem.charPosToLoc(textMem.char.count).locV
            hope this helps!
            - Ben
            • 3. Re: text placement
              Level 7
              Thanks Ben and Sean. I got distracted on something else and have just got back to
              this problem.
              Yes, I found that the linecount wasn't working for me. I'll try the first and last
              character check. Otherwise, maybe the alignment one.
              Thanks.
              • 4. Re: text placement
                Level 7
                Hi Sean and Ben,
                The code given in Sean's reply wasn't quite what I was after. When I was asking
                about alignment, I meant to align one sprite to another using Lingo. The
                'tTextMember.alignment = #center' just relates to character alignment in the text
                member itself. and, the linecount wasn't working for me as a I have a long text
                member wrapping onto multiple lines.
                However, I worked out a way to get the result I'm after. I start with tha locV of
                my text sprite as it should be if it was one line. Then I use the following:
                on beginSprite me
                textMem = sprite(me.spriteNum).member
                if firstCharV <> lastCharV then
                difference = lastCharV - firstCharV
                sprite(me.spriteNum).locV = sprite(me.spriteNum).locV - difference/2
                end if
                end
                Thanks guys for getting me here.
                • 5. Re: text placement
                  Level 7
                  Hi Sean and Ben,
                  on beginSprite me
                  end if
                  end
                  • 6. Re: text placement
                    Level 7
                    Hi Sean and Ben,
                    on beginSprite me
                    end if
                    end
