• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Query of Query Case Sensative
Explorer ,
Apr 27, 2006 Apr 27, 2006
Hello all
Got a simple problem, I run a main query:
<CFQUERY name="getprice" datasource="adatabase">
SELECT RTRIM(plpart) AS plpart, MIN(plunitprice) AS plunitprice
FROM pricelist
GROUP BY plpart
</CFQUERY>
now in the table pricelist some parts are entered in lowercase i.e the results could look like below:
Part____Price
ABc, 10
DeF, 11
ghi, 12
JKL, 10
If I query the datasource direct there is no problem with the case being upper or lower, but when I query of query like below it only returns a result if the LIKE '#variable#' is the correct case, how do I get around this?
<CFquery dbtype="query" name="qoq_price">
SELECT plunitprice
From getprice
WHERE plpart LIKE '#variable#'
</CFquery>
for example
if variable was 'ABc' the QOQ returns the correct price of 10
but
if variable was 'ABC' the QOQ does not return a result
Trouble is my variables come from one table where they are all in Upper case but in my price table people have entered them in both cases and sometimes mixed.
Kind Regards Guy
TOPICS
Advanced techniques
Views
982
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Apr 27, 2006 Apr 27, 2006
Thanks Peter
Completely passed my mind to just grab the SQL in Upper case, was to busy trying to look for a ignore case thingy.
Any way works a treat thanks
Votes
Translate
Translate
Participant ,
Have you tried something like this?
WHERE UCase(plpart) LIKE '#UCase(Variable)#'
Votes
Translate
Translate
Report
Report
Explorer ,
The bold bit throws an error
Query Of Queries syntax error.
Encountered "( plpart ) LIKE" at line 4, column 12. Incorrect conditional expression, Expected one of [like|null|between|in|comparison] condition, Unrecognized comparison operator,
This works
WHERE plpart LIKE '#UCase(Variable)#'
But then im turning the wrong side into upper case.
I need a kind of no case or ignore case format so in PSUDO it would be somthing like
WHERE plpart LIKE #ignorecase(#variable#)#
if you see what i mean.
Regards Guy
Votes
Translate
Translate
Report
Report
Participant ,
Ooops, you need to use Upper for the SQL side of things:
WHERE Upper(plpart) LIKE '#UCase(variable)#'
That (or Lower/LCase) is the simplest way to ignore case - I'm not aware of any specific case-insensitive flag that is available.
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
Thanks Peter
Votes
Translate
Translate
Report
Report
Resources
Documentation
