3 Replies Latest reply on Feb 5, 2016 8:51 AM by Fluid Junction
    Coldfusion 11, Mac Yosemite: Will not start,stop,scan at all
    inked_koi Level 1
      I've been wrestling with Coldfusion 11 for a the past couple of days attempting to start the server so I can at launch the program. But, no matter what I do or try it won't start.
      When I go into terminal and type:
           /Applications/ColdFusion11/cfusion/bin
      Results in: No such file or directory
           The folder is at that location, everything is there.
      So I'll try to start Coldfusion via Terminal
      Results in:     You must be the root user to configure the ColdFusion to start on System boot. Start ColdFusion as "sudo ./coldfusion start" to configure.
                     Once it has been configured, start ColdFusion as "./coldfusion start" to run ColdFusion as non-root user.
      Then I'll try
      Results in: sudo: ./coldfusion: command not found
      What am I doing wrong?
        • 1. Re: Coldfusion 11, Mac Yosemite: Will not start,stop,scan at all
          Elfwyne
          I have this same problem as I just installed CF - did you ever get it to work?
          • 2. Re: Coldfusion 11, Mac Yosemite: Will not start,stop,scan at all
            hanadul
            No, I gave up and uninstalled everything. I couldn't make it work at all no matter what I tried.
            • 3. Re: Coldfusion 11, Mac Yosemite: Will not start,stop,scan at all
              Fluid Junction Level 1
              Hi all,
              I'm on a Mac w/ El Capitan (10.11.3) and ColdFusion 11. First I'll tell you my initial experience and then my solution. I'm going to be overly detailed for those that may find this and need it ;-)
              My Initial Experience:
              Once the initial ColdFusion 11 installation was complete and it was time to open the Terminal... I opened the Terminal and typed the following: cd /Applications/Coldfusion11/cfusion/bin
              That went well so then I typed: ./coldfusion start
              That gave me the response mentioned in the original post "You must be the root user to configure the ColdFusion to start on System boot. Start ColdFusion as "sudo ./coldfusion start" to configure. Once it has been configured, start ColdFusion as "./coldfusion start" to run ColdFusion as non-root user."
              So I typed "sudo ./coldfusion start" but that gave me the "... command not found..." response - so then I started over completely - For whatever reason I believe this is the trick... starting over from step one after receiving the above response is the only way I was able to move forward.
              My Solution:
              Step 1: (On Mac) Open the Terminal and type the following: cd /Applications/Coldfusion11/cfusion/bin
                           (and then hit return)
              Step 2: Next, type the following: sudo ./coldfusion start
                           (you may be prompted for your password after hitting "return" - if so, enter it and hit return again)
              Step 3: Next, and finally, type: ./coldfusion start
              Once the Terminal responds letting you know that the ColdFusion 11 server has been started you can log into the ColdFusion 11 Administrator via a browser using the URL given to you upon completing the initial installation.
              Hope that helps...
