6 Replies Latest reply on Sep 18, 2015 12:38 AM by Vamitul
    read xml
    Level 1
      I need to read the xml file and get the attribute value
      <?xml version="1.0" encoding="UTF-8"?>
      <SOURCE>
          <Paragraph ParaNumber="Pg_1_P_3"/>
          <Paragraph ParaNumber="Pg_1_P_4"/>
      </SOURCE>
      var outmyf=Folder.selectDialog("Choose Out folder path");
      var FilePath=new File(outmyf+"/PageNumber.xml");
      //alert (FilePath)
      var xmlFile = new File(FilePath);
      if(xmlFile.exists)
          var xmlFileOpenFlag = xmlFile.open("r");
          if(xmlFileOpenFlag == true)
              var xmlFileContents = xmlFile.read();
              var root = new XML(xmlFileContents);
              var Pageno = root.xpath("/SOURCE/Paragraph[@ParaNumber]");
      But I need only the attribute value of the xml element the above code returning all the values.
        • 1. Re: read xml
          Ronald63 Level 4
          Try this...
          //alert (FilePath)
          if(xmlFile.exists)
                  var Pageno = root.xpath("/*/@ParaNumber");
                  len= Pageno.length();
                  while (len --){
                      var ParaNumberValue = Pageno[len];
                      alert(ParaNumberValue);
          Regards
          • 2. Re: read xml
            Marc Autret Level 4
            Note that root.xpath("/*/@ParaNumber") can be abbreviated root.*.@ParaNumber (this returns the same XMLList).
            Also, the para numbers can be collected into an Array this way:
            var a = root.*.@ParaNumber.toXMLString().split(/[\r\n]+/);
            alert( a );
            Marc
            • 3. Re: read xml
              Level 1
              Its working marc thanks for this.
              • 4. Re: read xml
                Loic.Aigon Adobe Community Professional
                You can even go straighter
                x..@ParaNumber
                The only interest in using an intermediate state would have been to only adress @ParaNumber whose parent is X or Y like
                x..foo.@ParaNumber
                FWIW,
                Loic
                • 5. Re: read xml
                  And you don't need to force an array conversion as a XMLList is an array-like.
                  var myAttrs = x..@ParaNumber;
                  var n = myAttrs.length();
                  while ( n-- ) {
                    $.writeln ("n:"+ myAttrs[n] );
                  FWIW,
                  Loic
                  • 6. Re: read xml
                    Vamitul Level 4
                    One weirdness to note, both approaches will fail if the xml only contains one instance of the searched element:
                    root.xpath(/*/Para).nodeKind()->Element if only one found (length() is 0)
                    root.xpath(/*/Para).nodeKind()->XMLList if more than one found (length() is whatever)
