10 Replies Latest reply on Sep 16, 2015 10:39 PM by Mizzou95
    Web module not loading correctly
    Mizzou95
      Hello,
      I have the most recent version of Lightroom 2015CC, and the Web Module is not working. I am going to try to attach a screen grab (bear with me, it is one of the first times using this forum for me) but basically the "main" center window just says loading and never loads correctly (no matter what template you try to select). I have tried to have Adobe reps look at it but quite honestly when it takes them 10-15 minutes to do one thing it is painfully slow and I don't have a 6 hour block of time for them to run through their entire playbook. (I wish I were kidding but it is painfully slow to watch them with control of my PC) This is on a Windows 10 system. So far we have eliminated the GPU acceleration as being the cause (still does it either way with that preference checked or unchecked) it is not the specific library, it does it with any library. Heck I've even unistalled and reinstalled Lightroom to my machine. Any other thoughts on this one are greatly appreciated.
        • 1. Re: Web module not loading correctly
          Akash Sharma Adobe Employee
          Hi Mizzou
          Please reset Lightroom Preferences as well
          Backup your Current catalog.Go to Edit>>Catalog Settings and select Next time Lightroom exists in Backup catalog section
          Image result for backup Lightroom catalog
          Then Close Lightroom Press and hold Alt+Control+Shift as you start Lightroom.You will be prompted to reset preferences,Select Yes The new preferences files are created the next time you start Lightroom
          Let us know if that helps
          ~Akash
          • 2. Re: Web module not loading correctly
            Mizzou95 Level 1
            Followed those steps and no change. Interestingly enough if I select preview in web browser it will show you what it looks like, but that center window is not loading at all.
            • 3. Re: Web module not loading correctly
              Try creating a new Lightroom catalog from File>>New catalog
              Import few Jpeg images and see if you can create an HTML gallery or select any other Gallery Tamplate
              • 4. Re: Web module not loading correctly
                Mizzou95 Level 1
                Nope, no luck with that either
                • 5. Re: Web module not loading correctly
                  What happens when you Export or Preview in Browser?Are you able to see Pictures in Preview or Exported gallery?
                  • Turn off GPU from Preferences again once.And see if there is a change
                  • Run Lightroom as Administrator.Right Click Lightroom icon and select "Run as Administrator"
                  • Create a new user account on your Computer and check if you can view Web gallery How to Create a New Local User Account in Windows 10
                  Akash
                  • 6. Re: Web module not loading correctly
                    Mizzou95 Level 1
                    Turning off GPU made no difference.
                    Running it as administrator made no difference.
                    I am not creating a whole other account and screwing up my computer because something of Adobe's is not working right. It once worked, it doesn't anymore, I am not creating a whole other account, so sorry Adobe you'll just have to work on fixing the problem without that.
                    • 7. Re: Web module not loading correctly
                      Mizzou95 Level 1
                      I forgot to add although I think I mentioned it orignially if I select preview in web or export it works, but it is essentially flying blind by never bringing up that center screen.
                      • 8. Re: Web module not loading correctly
                        We Apologize for the inconvenience
                        Request you Send us the  System info
                        In Lightroom, Go to Help>>System info and post the report here
                        Regards
                        Akash
                        • 9. Re: Web module not loading correctly
                          Mizzou95 Level 1
                          Lightroom version: CC 2015.1.1 [ 1032027 ]
                          License: Creative Cloud
                          Operating system: Windows 8.1 Home Premium Edition (Note I am running Windows 10 not 8.1, I upgraded from 8.1)
                          Version: 6.3 [9600]
                          Application architecture: x64
                          System architecture: x64
                          Logical processor count: 8
                          Processor speed: 2.3 GHz
                          Built-in memory: 16316.0 MB
                          Real memory available to Lightroom: 16316.0 MB
                          Real memory used by Lightroom: 479.3 MB (2.9%)
                          Virtual memory used by Lightroom: 426.3 MB
                          Memory cache size: 157.5 MB
                          Maximum thread count used by Camera Raw: 4
                          Camera Raw SIMD optimization: SSE2
                          System DPI setting: 96 DPI
                          Desktop composition enabled: Yes
                          Displays: 1) 1920x1080
                          Input types: Multitouch: No, Integrated touch: No, Integrated pen: No, External touch: No, External pen: No, Keyboard: No
                          Graphics Processor Info:
                          GeForce GT 740M/PCIe/SSE2
                          Check OpenGL support: Passed
                          Vendor: NVIDIA Corporation
                          Version: 3.3.0 NVIDIA 347.88
                          Renderer: GeForce GT 740M/PCIe/SSE2
                          LanguageVersion: 3.30 NVIDIA via Cg compiler
                          Application folder: C:\Program Files\Adobe\Adobe Lightroom
                          Library Path: D:\Pictures\Lightroom\Lightroom Catalog.lrcat
                          Settings Folder: C:\Users\Brian\AppData\Roaming\Adobe\Lightroom
                          Installed Plugins:
                          1) Behance
                          2) Canon Tether Plugin
                          3) Costco Photo Center
                          4) Facebook
                          5) Flickr
                          6) HDR Efex Pro 2
                          7) Leica Tether Plugin
                          8) Nikon Tether Plugin
                          9) Perfect Effects 8
                          Config.lua flags: None
                          Adapter #1: Vendor : 8086
                            Device : 416
                            Subsystem : 1963103c
                            Revision : 6
                            Video Memory : 112
                          Adapter #2: Vendor : 10de
                            Device : 1292
                            Revision : a1
                            Video Memory : 7b4
                          Adapter #3: Vendor : 1414
                            Device : 8c
                            Subsystem : 0
                            Revision : 0
                            Video Memory : 0
                          AudioDeviceIOBlockSize: 1024
                          AudioDeviceName: Speakers / HP (IDT High Definition Audio CODEC)
                          AudioDeviceNumberOfChannels: 2
                          AudioDeviceSampleRate: 44100
                          Build: LR5x102
                          Direct2DEnabled: false
                          GPUDevice: not available
                          OGLEnabled: true
                          • 10. Re: Web module not loading correctly
                            Mizzou95 Level 1
                            Of all weird things I had an issue with Windows 10 and the Settings window/app/box whatever they are calling it now not working. It got to the point the Microsoft tech had me reinstall Windows 10 (which managed to install but not kill off everything on my computer so that was nice) but in that process somehow the Web module was fixed as well, so not sure what wasn't happy but it's back!
