2 Replies Latest reply on Sep 14, 2015 10:40 AM by Anthony Harry_773
    a href not working in IE ( Downloading documents )
    Anthony Harry_773
      Hi
      This is the portion of code
      <a href="linuxpath/filename.doc">filename.doc</a>
      when I click on filename.doc its asking the option to save in mozilla but in IE its directly opening in browser in bad format .
      The same code is working fine in CF9 , we just installed CF11 in new Linux env and facing this issue
      Can anyone help on this please
      Amar
        • 1. Re: a href not working in IE ( Downloading documents )
          WolfShade Level 4
          Instead of linking directly to the file, I'd recommend having the link open a "download.cfm" file, pass an ID or filename as a URL parameter, and use CFCONTENT and CFHEADER to serve the file.  You can set it for inline or attachment - IE will offer you the choice, regardless.
          HTH,
          ^_^
          UPDATE:  Here is how I do it, if you're interested.
          <cffile action="readbinary" file="#ExpandPath('./')##filename#" variable="pdfBinary" />
          <cfheader name="Content-Disposition" value="attachment; filename=#filename#" charset="utf-8" />
          <cfcontent type="application/pdf" variable="#pdfBinary#" reset="yes" />
          • 2. Re: a href not working in IE ( Downloading documents )
            Anthony Harry_773 Level 1
            Thank you for the response .
            I will try to check with your code . But there are many places and we are trying to avoid any coding during this migration , so trying to find out any changes to configuration files  or some patch updates that might be available to resolve this issue
