1 Reply Latest reply on Sep 14, 2015 1:04 PM by Jeff Almasol
    Dangle Collapsing Entire Necklace
    dalesandberg Level 1
      Jeff/Team,
      First of all great work with Preview 2. It has certainly smoothed out a lot of the issues I and others were having with Preview 1.
      My current issue is with getting illustrator artwork to dangle properly. I have a necklace (more like a lanyard) around a characters neck. When I apply a dangle to the lanyard the strings that should be holding it around the characters neck fall and dangle as well. I have tried using fixed point, using a different attach to, and changing the position of the origin and dangle points, but nothing has solved the issue. I would be happy to send a file to a staffer if they could help.
        • 1. Re: Dangle Collapsing Entire Necklace
          Jeff Almasol Adobe Employee
          Hi Dale... Yes, please send us a shared link to the artwork you're trying to use. You can send it to me in a direct message in case you need to keep the artwork private.
          There was a change to how Dangle should be set up between Preview 1 and 2, but it sounds like you tried setting up a Fixed handle already. We can investigate what's going on.
          Thanks.
