• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
SaveForLater- after migration from CF8 to CF11
Community Beginner ,
Sep 14, 2015 Sep 14, 2015
After migration from CF8 to CF11, my users cannot save the application and continue at later time. The application still work fine under CF8. The application uses the registry to store the values. I have
Pool Discharge Permit Application
Your application has been saved. Click here to continue your application now.
To return to your application at a later time, simply re-visit the Pool Discharge Permit link you used to get to this application. Or you can add this page to your "Favorites" list.
(Please note: returning to a saved application only works if you are on the same computer.)
You can also print your application in its current state for mailing or faxing. Click here to print.
Views
319
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Sep 15, 2015 Sep 15, 2015
Could you show us the part of the code that you are having difficulty with?
Votes
Translate
Translate
Report
Report
I am not getting any errors, when you click the SaveForLater button, but when you return to the page, it is not showing the correct page. The page should  acknowlege that there is a saved application, Click Yes to continue the previous application or No to start a new application.
<cfparam name="client.poolDischarge" default="">
<cfparam name="m" default="checkClient">
<cfparam name="v" default="">
<cfswitch expression="#m#">
<cfcase value="checkClient">
  <cfif v eq "" and len(client.pooldischarge)>
   <cfset v = "hasClient">
  <cfelse>
   <cfset v = "apply">
  </cfif>
</cfcase>
<cfcase value="clear">
  <cfset client.poolDischarge = "">
  <cfset v = "apply">
</cfcase>
<cfcase value="print">
  <cfset currentApplication = application.poolDischarge.createApplication(argumentCollection = form)>
  <cfset application.poolDischarge.saveApplication(currentApplication)>
  <cfset v = "print">
</cfcase>
<cfcase value="save">
  <cfset v = "saved">
</cfcase>
<cfcase value="validateAddress">
  <cfset v = "validating">
</cfcase>
<cfcase value="validateAddressRetry">
  <cfset currentApplication = application.poolDischarge.getSavedApplication()>
  <cfset currentApplication.Discharge_Address_Entered = form.Discharge_Address_Entered>
  <cfset currentApplication.Discharge_Address_Number = "">
  <cfset currentApplication.Discharge_Address_Street_Name = "">
  <cfset currentApplication.Discharge_Address2 = form.Discharge_Address2>
  <cfset currentApplication.Discharge_City = form.Discharge_City>
  <cfset currentApplication.Discharge_State = form.Discharge_State>
  <cfset currentApplication.Discharge_Zip = form.Discharge_Zip>
</cfcase>
<cfcase value="submitApplication">
  <cfset currentApplication.Discharge_Address_Number = form.Discharge_Address_Number>
  <cfset currentApplication.Discharge_Address_Street_Name = form.Discharge_Address_Street_Name>
  <cfif currentApplication.Pro_Discharge eq 1 and currentApplication.Maintenance_Company_ID eq -1>
   <!--- Create a new one --->
   <cfset currentApplication.Maintenance_Company_ID = application.poolDischarge.insertMaintenanceCompany(argumentCollection = currentApplication)>
  </cfif>
  <cfset application.poolDischarge.insertApplication(argumentCollection = currentApplication)>
  <cfset application.poolDischarge.sendNewApplicationEmail()>
  <cflocation url="?v=thankyou&m=0" addtoken="No">
</cfcase>
</cfswitch>
<cfoutput>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<html>
<head>
<title>CCCSD Pool Discharge Application</title>
<link href="common/base.css" rel="stylesheet" type="text/css">
<script src="common/scripts.js" type="text/javascript"></script>
<script src="common/extendedDate.js" type="text/javascript"></script>
<script type="text/javascript" src="http://maps.google.com/maps/api/js?sensor=false"></script>
</head>
<cfparam name="onloadProcs" default="">
<body onLoad="doLoadProc();#onloadProcs#">
<center>
<div id="logoBar"><div class="logoBox"><img src="common/images/logo.gif" width="401" height="88" alt="" border="0"></div></div>
<div id="contentArea">
  <h1>Pool Discharge Permit Application</h1>
  <cfswitch expression="#v#">
   <cfcase value="hasClient">
    <p>We have found an application in progress. Would you like to resume the previous application?</p>
    <p>
     <a href="?v=apply">Yes. Continue my previous application.</a><br>
     <a href="?m=clear">No. I'd like to start a new application.</a>
    </p>
   </cfcase>
   <cfcase value="saved">
     doPrint = function() {
      document.getElementById("printFrame").src = "print.cfm";
    </script>
    <p>Your application has been saved. <a href="?v=apply">Click here</a> to continue your application now.</p>
    <p>
     To return to your application at a later time, simply re-visit the <a href="#script_name#">Pool Discharge Permit</a> link you used to get to this application. Or you can add this page to your "Favorites" list.<br>
    </p>
    <p>You can also print your application in its current state for mailing or faxing. <a href="" onclick="doPrint(); return false;">Click here to print</a>.</p>
    <iframe id="printFrame" width="695" height="1" frameborder="0" name="printFrame"></iframe>
   </cfcase>
   <cfcase value="apply">
    <cfinclude template="interfaces/application-form.cfm">
   </cfcase>
   <cfcase value="validating">
    <cfinclude template="interfaces/validate-address.cfm">
   </cfcase>
   <cfcase value="thankyou">
    <p>Thank you. Your application has been received and will be reviewed within 72 hours.</p>
    <p>Do you need to request another Pool Discharge Permit?  <a href="?v=apply">Submit a new application.</a></p>
   </cfcase>
  </cfswitch>
</div>
</center>
</body>
</html>
</cfoutput>
Votes
Translate
Translate
Report
Report
Community Expert ,
The case you describe is missing from the code you have provided. The two cases in the code that come close to your description are:
    <p>
    </p>
</cfcase>
    <p>
    </p>
</cfcase>
Votes
Translate
Translate
Report
Report
LATEST
Those are the correct cases that you mentioned. These cases work when I use the Coldfusion 8, but not in Coldfusion 11. Also I am using IIS 8.5
    <p>
    </p>
</cfcase>
    <p>
    </p>
</cfcase>
Votes
Translate
Translate
Report
Report
Enthusiast ,
Consider moving storage to a NoSQL datasource, database or file system as the registry is the worst possible place to store client data.
http://www.coldfusionmuse.com/index.cfm/2009/10/27/registry.bad.datasource.good
http://stackoverflow.com/questions/1228506/coldfusion-client-storage
http://www.dopefly.com/pages/coldfusionclientvariablesfinalnail.cfm
http://www.isummation.com/blog/strange-coldfusion-issue-jrun-eating-up-to-50-of-cpu/
Here's an undated quote from Adobe regarding ColdFusion MX 6/7:
ColdFusion MX 6.1 and MX 7: Troubleshooting client variable issues on Windows
There are many variations of hangs on production systems related to client variable use with the Windows Registry. The Windows Registry is not supported for production applications.
Votes
Translate
Translate
Report
Report
Resources
Documentation
