6 Replies Latest reply on Sep 17, 2015 5:39 PM by romanobstuder
    Multi Dimensional Array | Object
    romanobstuder Level 1
      Hi all
      I have created a script that traverses all tables in a document and collects text strings that are formatted with a character style "Footnote_Marker".
      (InDesign does not support Footnotes in Tables.)
      Every found entry gives me 2 parts:
      myPage (this is an object) and myFootnoteString (This is a string)
      var myPageName = myPage.name;   <----- This gives me a human readable page number
      The string can be something like "1" or "7" or "***"or "VISA only"
      Many entries of "1" could be found on Page X, (The footnote will always mean the same thing in the complete catalogue, for example 1 = Made in Italy
      So now I need to hold this data in a sensible construct.
      I would like to have only one Array Key for the pages with many Secondary Key entries for the string.
      Also if I find the Footnote marker "1" many times on the page it needs to go into the Array only once.
      And I need to be able to alpha sort the Footnotes.
      I already played with Arrays and Objects in Javascript but nothing works for me...
      Appreciate your help
      Regards
      Romano
        • 1. Re: Multi Dimensional Array | Object
          Here is some code I work with:
          var myPageFootnoteData = {};
          var myPage;
              var myFootnoteString;
              myPage = "aaaa";
              myFootnoteString = "AAAAA";
              addPageFootnote(myPageFootnoteData, myPage, myFootnoteString);
              myPage = "bbbb";
              myFootnoteString = "BBBBBB";
              myPage = "cccc";
              myFootnoteString = "CCCCCCCC";
              myPage = "dddd";
              myFootnoteString = "DD";
              myPage = "dddd";
              myFootnoteString = "12345";
              myPage = "dddd";
                      $.writeln("Checkpoint_02");
              outputDataArray(myPageFootnoteData);
          function addPageFootnote(myPageFootnoteData, myPage, myFootnoteString){
              $.writeln("This is my main object: " + myPageFootnoteData);
              $.writeln("This is the page: " + myPage);
              $.writeln("This is the footnote: " + myFootnoteString);
              //$.writeln("Cold call: show me the page: " + myPageFootnoteData[myPage].myPage);
              //var myPageHolder;
            var myPageHolder;
            var myFootnoteStringHolder;
              if(myPageHolder in myPageFootnoteData == false){
                  myPageFootnoteData[myPageHolder] = {};
                  $.writeln("It did not exist We insert this: " + myPage);
                  myPageFootnoteData[myPageHolder] = myPage;
                  $.writeln("OK show me the page: " + myPageFootnoteData[myPageHolder]);
                  $.writeln("Checkpoint_01a");
              if (myFootnoteStringHolder in myPageFootnoteData == false) {
                  $.writeln("Checkpoint_01");
                  //$.writeln("2OK show me the page: " + myPageFootnoteData[myPage]);
                  myPageFootnoteData[myFootnoteStringHolder] = {};
                              $.writeln("Checkpoint_20");
          • 2. Re: Multi Dimensional Array | Object
            Here is a workable code.
            I can create the first outer Array (it is actually a raw Object).
            But the inner Array loop is not working at all.
            It is possible that I don't understand the Array concept at all. So if you can give me a helping hand that would be greatly appreciated.
            Regards
            Romano
            main();
            function main(){
                $.writeln("Checkpoint_0000");
                myPageFootnoteDataFunction(myPageFootnoteData);
            function myPageFootnoteDataFunction(myPageFootnoteData){
                $.writeln("This is the Object myPageFootnoteData: " + myPageFootnoteData);
                $.writeln("This is the Object myPageFootnoteData Length: " + myPageFootnoteData.length);
                var myPage;
                myPage = "1";
                myPage = "2";
                myFootnoteString = "BBBBB";
                myPage = "3";
                myFootnoteString = "CCCCC";
                myPage = "4";
                myFootnoteString = "DDDDD";
                myPage = "4";
                myPage = "4";
                        $.writeln("Checkpoint_03");
                for(var a in myPageFootnoteData){
                    //$.writeln("[" + a + "]" + " ___ " + myDataArray[a].myPageName + " ___ " + myDataArray[a][a].myFootnoteString);
                        $.writeln("Array Key 01 and 02  Outside [" + myPageFootnoteData + "]" + " ___ " + myPageFootnoteData[a][b] + " ___ ");
                   for(var b in myPageFootnoteData[a]){
                        //$.writeln(string = string + myPageFootnoteData[a][b]+",");
                        $.writeln("Array Key 01 and 02  Inside [" + myPageFootnoteData[a] + "]" + " ___ " + myPageFootnoteData[a][b] + " ___ ");
                var myPageHolder;
                if (myFootnoteStringHolder in myPageFootnoteData[myPageHolder] == false) {
                //$.writeln("3OK show me the page: " + myPageFootnoteData[myPage]);
                //$.writeln("4: " + myPageFootnoteData[myPage][myFootnoteString]);
                //myPageFootnoteData[myPage][myFootnoteString] = myFootnoteString;
                //$.writeln("5: " + myPageFootnoteData[myPage][myFootnoteString]);
                //$.writeln("Final test A: " + myPageFootnoteData[myPage]);
                //$.writeln("Final test B: " + myPageFootnoteData[myPage][myFootnoteString]);
            function outputDataArray(myPageFootnoteData){
                    $.writeln("Array Key 01 [" + a + "]");
                                $.writeln("Checkpoint_10");
                                    $.writeln("Checkpoint_11");
                        $.writeln("Array Key 02 [" + b + "]" );
            • 3. Re: Multi Dimensional Array | Object
              Peter Kahrel Adobe Community Professional & MVP
              Hi Romano,
              Maybe you could use a method along these lines:
              Two objects: 'known' to keep track of notes placed on a page and and 'obj' to store your data
              known = {};
              obj = {};
              For every found object, (a) if the page doesn't exist as a key, add a key, its value will be the string as a single-element array; (b) if the page key exists, add the string to the array if it's not yet in the array:
              if (obj[myPage] === undefined) {
                 obj[myPage] = [myString];
              } else {
                 if (!known[myPage+'/'+myString]) {
                    obj[myPage].push(myString);
                    known[myPage+'/'+myString] = true;
              Now you have an object with unsorted keys/page numbers, and each key has an array of unsorted arrays. You can't sort objects, so transfer it to an array. And while you're doing this, sort the arrays:
              arr = [];
              for (i in obj) {
                 arr.push ({page: Number(i), notes: obj[i].sort()});
              Then sort the array by page number:
              arr.sort (function(a,b) {return a.page-b.page});
              Hope this helps
              Peter
              • 4. Re: Multi Dimensional Array | Object
                Hi Peter
                Thank you very much!
                I still try to understand what happens when we go into the arr
                I guess page and notes is what I am looking for.
                How do I know travers and output the arr data?
                I end up with the keys, not the data that they hold, I think
                Regards
                Romano
                main();
                function main(){
                    var known = {};
                    var obj = {};
                    myPageFootnoteDataFunction(known, obj);
                    mySortPageFootnote(known, obj);
                function myPageFootnoteDataFunction(known, obj){
                    var myPage;
                    myPage = "1";
                    addPageFootnote(known, obj, myPage, myFootnoteString);
                    myPage = "2";
                    myPage = "3";
                    myPage = "4";
                    myPage = "4";
                    myFootnoteString = "ddd";
                    myPage = "4";
                    myPage = "4";
                function addPageFootnote(known, obj, myPage, myFootnoteString){
                        obj[myPage] = [myFootnoteString];
                    } else {
                        if (!known[myPage+'/'+myFootnoteString]) {
                            obj[myPage].push(myFootnoteString);
                            known[myPage+'/'+myFootnoteString] = true;
                    $.writeln("2OK show me the page: " + obj[myPage]);
                    $.writeln("3OK show me the page: " + known[myPage+'/'+myFootnoteString]);
                function mySortPageFootnote(known, obj){
                    arr = [];
                    for (i in obj) {
                    outputDataArray(arr);
                function outputDataArray(arr){
                    for(var a in arr){
                        for(var b in arr[a]){
                            for(var c in arr[a][b]){
                                $.writeln("Array Key 03 [" + c + "]" );
                • 5. Re: Multi Dimensional Array | Object
                  You could write the array like this:
                  for (i = 0; i < arr.length; i++) {
                     $.writeln ('Page: ' + arr[i].page + ', notes: ' + arr[i].notes.join(', '));
                  P.
                  • 6. Re: Multi Dimensional Array | Object
                    Super! I had no idea about the .join.
                    Thank you very much for this. All the best and talk soon.
                    Regards
                    Romano
