• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
JQuery datepicker question with Cold Fusion
Explorer ,
Sep 16, 2015 Sep 16, 2015
Noticed that there is JQuery modules in the directories with Cold Fusion 11.
In the URL "http://stackoverflow.com/questions/15756532/use-jquery-datepicker"  shows using JQuery local for the date picker on the server. But it show a module datepicker.css.
I cannot find the module.
Does JQuery need to be downloaded in order to obtain all the modules for the datepicker?
Mike
Views
471
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
What directories do you mean?
Jquery is completely separate from CF, you will always need to include it manually if you want to use it on your page.
The date picker you are talking about will be a third party one that is based on jQuery. jQuery does have a normal date picker that is used in jQuery-UI package but again this needs to be manually included on your pages.
Votes
Translate
Translate
Report
Report
Explorer ,
The directory is: ColdFusion11\cfusion\wwwroot\CFIDE\scripts\ajax
Mike
Votes
Translate
Translate
Report
Report
Advocate ,
LATEST
This will be in there for CFs own internal javascript usage. This isn't for use on your pages. Some coldfusion ui elements will use certain javascript libraries, some of these probably require jquery. CFCalendar probably uses the date picker element from jquery, but will automatically use these files without you having to add them.
If you want to use date pickers, either use CFCalendar (Which i would not recommend, stay away from CF UI tools) or find the documentation for using jquery-ui and using the datepicker there.
Votes
Translate
Translate
Report
Report
Resources
Documentation
