1 Reply Latest reply on Sep 16, 2015 6:16 AM by Willam van Weelden
    DocBook export from robohelp 2015
    johanr44340384
      I got a export from our technical writer using the 2015 demo.
      The export was in xml using docbook.
      There are some redundant markup in the xml
      <section role="RHC.DUMMY">
      <title role="RHC.DUMMY"/>
      <simpara role="RHC.DUMMY"/>
      <para> </para>
      </section>
      Is there any way to prevent redundant markup like this during export?
        • 1. Re: DocBook export from robohelp 2015
          Willam van Weelden Adobe Community Professional & MVP
          The XML output (in this case DOCBOOK) is generated using XSLT. By modifying the XSLT, you control exactly how the output will work. The XSL used by RoboHelp is located in:
          C:\Program Files (x86)\Adobe\Adobe RoboHelp 2015\RoboHTML\XmlSupportExt\DocBook_HDF
          This is far from ideal, but short of (a) automating a cleanup of the sources after generation or (b) logging a bug report with Adobe, this is the only solution that I can think of.
