1. In my ColdFusion 11 website (with SQL Server 2008 R2), the following cfquery is throwing the above error:
<cfquery name="deleteGrantModificationItems" datasource="#dsource#">
DELETE col_key FROM myTable
WHERE col_key = <cfqueryPARAM value = "#appkey#" CFSQLType = "CF_SQL_VARCHAR">
</cfquery>
2. When I run the sql profiler to capture the query, I get:
eclare @p1 int
et @p1=NULL
exec sp_prepexec @p1 output,N'@P1 varchar(8000)',N'DELETE col_key FROM myTable
WHERE col_key = @p1 ','000000001644'
select @p1
3. when I run the above in the Query Analyzer, I get the following error:
Msg 208, Level 16, State 1, Line 1
Invalid object name 'col_key'.
Msg 8180, Level 16, State 1, Procedure sp_prepexec, Line 1
Statement(s) could not be prepared.
What could be the issue? Please help.
Your SQL is incorrect.
The statement should just be
DELETE FROM myTable
