3 Replies Latest reply on Aug 7, 2008 4:44 AM by Newsgroup_User
    Issue with using array as a function parameter
    BJWILD
      Im trying to create a functino that takes an array as a parameter and give it a default value of an empty array however im getting 1047: Parameter initializer is unknown with a number of ways I have tried.
      eg:
      public function foo( myArray:Array = [] ):void{
      // do stuff with the array
      generated this error:
      1047: Parameter initializer unknown or is not a compile-time constant.
      using myArray:Array = new Array() gives the same error...
      Anyone else come across this?
        • 1. Re: Issue with using array as a function parameter
          Level 7
          "BJWILD" <webforumsuser@macromedia.com> wrote in message
          news:g7dqkq$bqn$1@forums.macromedia.com...
          > it a
          > initializer
          > eg:
          try
          public function foo(myArray:Array=null):void{
          if (myArray==null){
          myArray=new Array();
          not sure why what you tried isn't working, but this is one way arround it...
          • 2. Issue with using array as a function parameter
            BJWILD Level 1
            Just got answer from Google Flex group...
            one possible answer is to initialitze it using the null value
            ie: myArray:Array = null
            • 3. Re: Issue with using array as a function parameter
              Level 7
              Glad you found that, since no one here was going to suggest that :-p
              news:g7dtbe$ech$1@forums.macromedia.com...
