0 Replies Latest reply on Sep 17, 2015 7:24 AM by efrénc65064057
    Code128 and Code128B renders the same barcode
    efrénc65064057 Level 1
      I need to set a code128 barcode but it renders in code128B. I used Livecycle Designer ES2 and ES4 with the same results.
      Ex.:
           <subform w="576pt" h="756pt">
               <field name="Code128BarCode3" y="6.35mm" x="6.35mm" w="190.5mm" h="13.594mm">
                  <ui>
                     <barcode type="code128" wideNarrowRatio="fixed" textLocation="above" dataLength="49"/>
                  </ui>
                  <font typeface="Courier New" size="8pt"/>
                  <value>
                     <text>905500000000009020152T9560367596351ET3HT000000HB0</text>
                  </value>
               </field>
               <?templateDesigner expand 1?>
               <field name="Code128BBarCode1" y="19.05mm" x="6.35mm" w="190.5mm" h="13.594mm">
                  <ui>
                     <barcode type="code128B" wideNarrowRatio="fixed" checksum="auto" dataLength="49"/>
                  </ui>
                  <font typeface="Courier New"/>
                  <value>
                  </value>
               </field>
            </subform>
      Renders:
      But an online web app renders:
      Regards.
