7 Replies Latest reply on May 14, 2006 5:42 AM by Newsgroup_User
    PHP Question - probably "oh-so" simple...
    Level 7
      I'm inputting the user's IP address into a disabled field on a contact form,
      like so:
      <input disabled ... value="<?php $ip= $_SERVER['REMOTE_ADDR']; echo $ip;?>">
      I want to have that address e-mailed to me - but I haven't been mailing
      strings before. This is how everything else is getting inserted into the
      message:
      $Message .= "E-mail Address: ".$_POST['email']."\r\n";
      How can I send the $ip in the message, too?
      Shane H
      shane@NOSPAMavenuedesigners.com
      http://www.avenuedesigners.com
        • 1. Re: PHP Question - probably &quot;oh-so&quot; simple...
          Level 7
          > message:
          It's not $ip that you put in the message, but whatever name you have
          given to that particular field. Say you have called it "ip", like this:
          <input name="ip" .... />
          The you get the value from $_POST['ip'].
          $Message .= "IP Address: ".$_POST['ip']."\r\n";
          David Powers
          Author, "Foundation PHP for Dreamweaver 8" (friends of ED)
          Author, "Foundation PHP 5 for Flash" (friends of ED)
          http://foundationphp.com/
          • 2. Re: PHP Question - probably &quot;oh-so&quot; simple...
            Level 7
            I should have mentioned that I did infact try that, and it comes up in the
            e-mail as:
            IP Address:
            Here is the code for the input field:
            <label for="ipaddress" class="labelbold">IP Address <span
            class="redast">*</span></label><br>
            <input disabled name="ipaddress" type="text" class="phonefield"
            id="ipaddress" value="<?php $ip= $_SERVER['REMOTE_ADDR']; echo $ip;?>"
            style="color: #000000">
            And here is the "adding to the e-mail code:
            $Message .= "IP Address: ".$_POST['ipaddress']."\r\n";
            Any suggestions on why it's getting a blank field e-mailed to me?
            Shane H
            "David Powers" <david@example.com> wrote in message
            news:e45cg2$kbt$1@forums.macromedia.com...
            > Shane H wrote:
            >> This is how everything else is getting inserted into the message:
            > It's not $ip that you put in the message, but whatever name you have given
            > David Powers
            • 3. Re: PHP Question - probably &quot;oh-so&quot; simple...
              Level 7
              The IP address will probably only be one from a block owned by the ISP, you
              know?
              Murray --- ICQ 71997575
              Adobe Community Expert
              (If you *MUST* email me, don't LAUGH when you do so!)
              http://www.dreamweavermx-templates.com - Template Triage!
              http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
              http://www.dwfaq.com - DW FAQs, Tutorials & Resources
              http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
              "Shane H" <shane@NOSPAMavenuedesigners.com> wrote in message
              news:e45csv$l1c$1@forums.macromedia.com...
              >e-mail as:
              > IP Address:
              > Shane H
              >> David Powers
              • 4. Re: PHP Question - probably &quot;oh-so&quot; simple...
                Level 7
                Because you have disabled the field. Use readonly instead.
                David Powers
                • 5. Re: PHP Question - probably &quot;oh-so&quot; simple...
                  Level 7
                  Huh?
                  Shane H
                  "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
                  news:e45g99$oqn$1@forums.macromedia.com...
                  > you know?
                  >>e-mail as:
                  >> IP Address:
                  >> Shane H
                  >>> David Powers
                  • 6. Re: PHP Question - probably &quot;oh-so&quot; simple...
                    Level 7
                    That's it - thank you David, works great now!
                    Shane H
                    news:e45ja9$s23$1@forums.macromedia.com...
                    > David Powers
                    • 7. Re: PHP Question - probably &quot;oh-so&quot; simple...
                      Level 7
                      I mean that you will probably only get the ISP's IP address block, not
                      anything specific to the user (unless the user has a static IP).
                      news:e467hs$jvp$1@forums.macromedia.com...
                      > Huh?
                      > Shane H
                      >> you know?
                      >>>the e-mail as:
                      >>> IP Address:
                      >>> Shane H
                      >>>> David Powers
