1 Reply Latest reply on Sep 18, 2015 4:44 AM by sreekarthik.k@gmail.com
    HTTP POST Request
    Level 1
      HTTP POST Request
      I need to HTTP POST to a webpage, and store server's output into a variable.
      here is the code. also i have copied the code from forum. But its not working. Any one have a idea how to post the data via scripting
      var response = make_HTTP_post('http://10.1.8.66',  ':8085/activiti-rest/service/runtime/process-instances',  { 'processDefinitionKey': 'photoshopTest',  'variables':[]  } );
      alert(response);
      function make_HTTP_post(domain, path, post_data) {
          var data_string = '';
          for ( var key in post_data ) {
              if ( post_data.hasOwnProperty(key) ) {
                  data_string += '&' + encodeURIComponent(key)
                   + '=' + encodeURIComponent(post_data[key]);
          data_string = data_string.substring(1); // discard first '&'
          var conn = new Socket;
          conn.open(domain + ':8085');
          conn.write('POST ' + path + " HTTP/1.1\r\n");
          conn.write('Host: ' + domain + "\r\n");
          conn.write('Content-Length: ' + data_string.length + "\r\n");
          conn.write("Content-Type: application/json\r\n");
          conn.write("\r\n");
          conn.write(data_string);
          alert (data_string)
          var reply = '';
          reply = conn.read(999999);
          conn.close();
          reply = reply.split("\n\n");
          reply.splice(0,1); // discard server headers
          return reply.join("\n\n");
