1 Reply Latest reply on Sep 19, 2015 12:09 AM by CarlosCanto
    Script inverte posições pelo centro do objeto
    beto correa Level 1
      Olá a todos!
      Preciso de uma Script que inverta posições de objetos selecionados pelo centro da imagem.
      Consegui fazer a inversão mas não consigo alinhar centro com centro. Alguém pode me ajudar?
      Obrigado!
      Hello everyone!
      I need a script that reverses positions of selected objects to the center of the image .
      I managed to turn it around but I can not align center center. Can someone help me?
      Thank you!
      try {
      var docRef = activeDocument;
      if (documents.length>0) {
        if (docRef.selection.length == 2) {
        mySelection = docRef.selection;
        //if object is a (collection of) object(s) not a text field.
        if (mySelection instanceof Array) {
        //initialize vars
        //create bounding objects
        var origBounds = mySelection[0].geometricBounds;
        var initBounds = mySelection[1].geometricBounds;
        //define paramaters of top object
        var oul_x = origBounds[0];
        var oul_y = origBounds[1];
        var olr_x = origBounds[2];
        var olr_y = origBounds[3];
        var oSelWidth = (olr_x-oul_x);
        var oSelHeight = (oul_y-olr_y);
        var oSelPos = [oul_x, oul_y];
        //define paramaters of bottom object
        var ul_x = initBounds[0];
        var ul_y = initBounds[1];
        var lr_x = initBounds[2];
        var lr_y = initBounds[3];
        var mySelWidth = (lr_x-ul_x);
        var mySelHeight = (ul_y-lr_y);
        var mySelPos = [ul_x, ul_y];
        //apply transforms to selection[0]
        mySelection[1].height = mySelHeight;
        mySelection[1].width = mySelWidth;
        mySelection[0].position = mySelPos;
        //apply transforms to selection[1]
        mySelection[0].height = oSelHeight;
        mySelection[0].width = oSelWidth;
        mySelection[1].position = oSelPos;
                  } else {
      } catch(e){
        • 1. Re: Script inverte posições pelo centro do objeto
          CarlosCanto Adobe Community Professional & MVP
          you're almost there,
          first, get each of the objects' centers
          var oSelPos = [oul_x+oSelWidth/2, oul_y-oSelHeight/2]; // center position
          var mySelPos = [ul_x + mySelWidth/2, ul_y-mySelHeight/2]; // center position
          then, move object 0 to center 1, and adjust half of object's width/height...same for object 1
          mySelection[0].position = [mySelPos[0]-oSelWidth/2, mySelPos[1]+oSelHeight/2];
          try {
              if (documents.length > 0) {
                          //initialize vars
                          var oSelWidth = (olr_x - oul_x);
                          var oSelHeight = (oul_y - olr_y);
                          var mySelWidth = (lr_x - ul_x);
                          var mySelHeight = (ul_y - lr_y);
                          //mySelection[0].position = mySelPos;
                          mySelection[1].position = [oSelPos[0]-mySelWidth/2, oSelPos[1]+mySelHeight/2];
                          //mySelection[1].position = oSelPos;
                      } else {}
          } catch (e) {}
