2 Replies Latest reply on Nov 27, 2006 9:29 AM by Marisol_1
    File is corrupt
    Marisol_1
      Hello,
      Has anyone gotten the following message when trying to open a project, and what exactly does it mean, or what am I doing wrong?
      "Your file project, C:\Program Files\Robohelp Office\RoboHTML\Arson\Arson.cpd, is corrupt and cannot be opened. Try deleting this file and reopening the .XPJ" I click OK, and the project opens up.
      Any help is appreciated. I juststarted to work in HTML.
      Thanking you in advance
      Marisol
        • 1. Re: File is corrupt
          RoboColum(n) Level 5
          Hi Marisol. There are a number of factors that can result in a corrupted CPD file. Working across a network and using RoboSource Control being two of them. If running RH across a network......stop! RH doesn't sit well on a network. Move your projects to your hard drive. If you are using RoboSource Control, corrupted CPD files occur quite often depending on what you are doing. The CPD file rebuilds itself automatically so just do as the message says: delete the project's CPD file and reopen the project.
          • 2. Re: File is corrupt
            Marisol_1 Level 1
            Thank you...I will do that.
            Marisol
