1 Reply Latest reply on Sep 18, 2015 11:56 AM by resdesign
    Any Javascript for Playing the result animation depending on Frame Rates(fps)?
    Kyle_KIM Level 1
      Hi!
      I know Edge Animate is time based animation.
      but I want to play it based on user defined Frame Rates(fps)
      It's like playing at intervals.--play(0), play(17), play(34)....
      I searched about this, but everyone says "no way"
      But I think now things are changed, we can add custom javascripts into Edge Animate projects.
      Problem is that I don't know javascripts, I am a developer from different field though.
      I can trigger javascript funtions inside Edge Animate from outside of the file like this:
      AdobeEdge.getComposition("EDGE-46542113").getStage().stop(1000))
      Using the code, I found out that calculating and stopping at every positions is a huge problem.
      so I think  if i get to have a function with a parameter inside the Edge Animate project, I could just trigger that and load once like:
      getStage().playAtIntervals(fps)
