4 Replies Latest reply on Sep 19, 2015 4:01 AM by Willi Adelberger
    Delete original images?
      I'm really new to indesign and self taught. I get around fine with the help of you tube (thanks to you guys!)
      Can someone explain the following to me/ fill me in.
      I'm using Indesign CS6 to make photo books, and I'm wondering if I have to keep the original images or does my Indesign file save them for printing later?
      I'm familiar with the broken link when you move an image- but I don't think I understand the concept since it still shows the image on that page.
      When I finish a book, I just want to keep the indesign file and discard the images.
      How will this work? obviously the broken link error will come up once I do that. But can I proceed like normal?
      Thanks for your help!
        • 1. Re: Delete original images?
          You need to keep the images, and ID must be able to find them. Broken or out of date links will result in poor quality output. All that is saved inside the file is a low-res screen preview.
          • 2. Re: Delete original images?
            ecpunk Level 1
            If all that's saved in the file is a low-resolution preview, how come my file is 80 MB? So far I have about 30 pages with pictures on them.
            If i keep up at this rate, I will soon be running out of disk space  .
            • 3. Re: Delete original images?
              Migintosh Level 4
              ecpunk wrote:
              …how come my file is 80 MB?
              Maybe some combination of a few factors. First, you can usually make the file size smaller if you periodically do a save-as. InDesign saves some data that deals with undos, and doing a save-as will wipe clean some info that is probably not doing anything for you. Also, if you are saving your images with 72ppi resolution, but shrinking the images after they are placed into InDesign to achieve a higher effective resolution, consider setting the target resolution to the file in Photoshop with resampling turned off. The image will look the same, you won't have to make them smaller after you place them, and the preview portion of the image (the part that gets saved in the InDesign file) will be smaller. You can try it with a test file if you like. Just place 5 or 6 72ppi images on a page with 300ppi effective resolution and save the file. Next, change the images to 300ppi in Photoshop and place them into a new doc and compare the file size. It will likely be lower.
              • 4. Re: Delete original images?
                Maybe that you have placed the images with embedding them and not linking them. This will increase the files size.
                But this would not be a recommended workflow because it is often causing problems and eventually ends in file corruption. Better is to link images, and go to File > Package… and keep that folder for the future.
